Old 07-11-2002, 07:57 AM
mike001 mike001 is offline
Default Slowing it down!!
Hi. I was hoping that someone may have the answer to this.
Is the any way to slow down already recorded music.
I tried it many ways with no great result.
I know there must be an easy way.
School me!!! [img]images/icons/smile.gif[/img]
M
Old 07-11-2002, 08:23 AM
digi2000 digi2000 is offline
Default Re: Slowing it down!!
I am sure you have tried Time stretching. One thing you can do is select all the audio files and then time stretch them all your desired speed. Depending on the number of audio files you are working with this could take quite a while but that would be the best way to tackle the problem in my opinion.
Old 07-11-2002, 09:02 AM
J. FO J. FO is offline
i've only managed to shrink things, everythime i've tried to strech something out inside PT using the time compression-expansion audiosuite plug, it has done weird things. i believe there are programs like gigasampler (that might not be one, but there is some out there) that allow you to mess with the BPM of a given sample. maybe you could do it this way.
Jeremy Forbis
Old 07-11-2002, 09:26 AM
pk_hat pk_hat is offline
import the whole track into Acid 3.0 if you have it, this would be the easiest way.
www.myspace.com/krou
Old 07-22-2002, 01:31 PM
ptrbas ptrbas is offline
I never used Time Compression Expander on a hole tune but it works like this:
Select audio>audiosuite&gt>Time compression Expander;click destination time>
fill in the bpm>enter>process.
When use in play list is selected you will see the new audio in your session.
Don't forget to make a back-up first [img]images/icons/wink.gif[/img]
Pieter
Old 07-22-2002, 01:49 PM
Last Last is offline
Ill give you a little heads up about the time comp-exp plugin : Play around with the crossfade.
You will also get better results with smaller changes to the piece.To more drastic the speed up-or slow down is,the harder it is going to be to get right.
If you're gonna laugh about it later, you may as well laugh about it now
Old 07-22-2002, 04:37 PM
<font size="2" face="Verdana, Arial">bump
Old 07-22-2002, 05:03 PM
Bloux Bloux is offline
Originally posted by Bloux:
I have to stay in PT's
[img]images/icons/frown.gif[/img]
<font size="2" face="Verdana, Arial">Bump!
Old 07-22-2002, 05:54 PM
Time Comp/Exp plug then.
source bpm: 104
dest bpm : 100
+ 'Process'
don't forget to highlight whatever file you need to process.
Old 07-22-2002, 06:14 PM
chriswebb chriswebb is offline
I've experienced wonderful results with the Audiosuite's time expression/compression tool.
Don't over use it or you'll be sorry. Apply the same effect settings to each track.
I'm doing voice overdubs on a jazz trio that recorded the music live last September. 2 songs had problems. One too fast, the other too slow-both by only a couple BPM.
I fixed it as described above no problem.
I ALWAYS make a backup of the recording directory whenever I perform such a drastic change. I highly recommend such practices.
Chris
Slowing down click willl3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-31-2007 09:50 PM
slowing down a song kneegrow Pro Tools M-Powered (Mac) 0 12-15-2005 03:40 PM
g5 slowing down! richsorr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-21-2004 11:43 PM
Seems like PT is slowing down... Dr. J Pro Tools TDM Systems (Mac) 10 07-16-2002 06:21 PM
PT5/G4 slowing down midimac Pro Tools TDM Systems (Mac) 1 04-15-2000 05:35 PM
