How to record a DJ mix into protools le (001) v6.4
Is there a way for me record a live dj mix (CDJs or Turntables) into protools le (digi001) v6.4 and capture each device sound individually on seperate protools tracks?
I know most DJ use laptop and software to perform live (serato or virtual dj), but is there a device or bridge that would allow me to plugin from a dj mixer to the digi001 to capture each turntable indiviually to record on seperate tracks? Thanks!
myspace.com/eklazz myspace.com/greatdamemusic |
Re: How to record a DJ mix into protools le (001) v6.4
def possible. High end dj mixers (don't quote me though) may have direct outs, or aux sends that you could use to record stems of your mix..
I would say that the easiest (but not cheapest) method would be to use standalone preamps (RIAA or line) which would allow you to split the signal between your dj mixer and PT. The cheapest way (if you are using line level sources) would be to simply purchase Y cables to split the signal. Hope that helps |
Thanks dubpimpjuice! If there are any more suggestions please replay.
Protools 8 + Record | Filmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-21-2010 12:52 PM |
Help! Protools won't record! | mynar7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-19-2009 08:06 PM |
At what level do you Record Into Protools LED? | sctstudios | Pro Tools TDM Systems (Mac) | 3 | 01-22-2007 12:16 PM |
ProTools said it can't record | brad f | Pro Tools TDM Systems (Mac) | 4 | 01-02-2003 09:14 AM |
setting record levels into ProTools with the intent of mixing in ProTools | Felix | Tips & Tricks | 507 | 02-05-2002 10:17 PM |
