bounce in Logic4.5=OK/bounce inPT5.0.1=FREEZE
sorry, but this is freaking me out.
Bounce of any numbers of tracks in Logic Plat.4.5 absolutely no problem! but then, in PT 5.0.1, EVERY time i try to bounce, even just 3 or 4 tracks, FREEZE! i dont get it, both softs use the same hardware, the same DAE, whats going on? 8600, CrescendoG4/450, 258ram, SBS-7slot expansion, formac videocard, i tried diff. memory and ext. settings i am lost, this worked on PT4.3 perfectly, anybody having an idea? |
Re: bounce in Logic4.5=OK/bounce inPT5.0.1=FREEZE
Have you tried replacing the stock 8600 processor to see if it's a problem with the Crescendo G4?
Lee Blaske |
<Have you tried replacing the stock 8600 processor to see if it's a problem with the Crescendo G4?>
not yet, didnt have the time to go thru this. actually i am working mostly in Logic, but some clients want to use PT. PT4.3 was working fine on the Crescendo, as did Logic. now only Logic is bullet proof, with the Velocity Engine enabled. is the PT5 optimized for G4(VelocityEngine)? thanks in advance |
Bounce to mp3 freeze? | xx1messxx | Windows | 2 | 08-12-2011 08:26 AM |
PT 9 Freeze after bounce ... | jeam25 | Windows | 8 | 06-23-2011 08:01 PM |
HD Native. Offline bounce/Freeze? | lifer | Pro Tools HDX & HD Native Systems (Mac) | 4 | 10-08-2010 07:30 AM |
freeze a few minutes into mix or bounce? | trevito | Digidesign Hardware & Software | 2 | 11-02-2000 12:44 AM |
bounce in Logic4.5=OK/bounce inPT5.0.1=FREEZE | plenky | Pro Tools TDM Systems (Mac) | 0 | 08-31-2000 04:01 PM |
