Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 04-18-2001, 09:45 PM
jkrebs jkrebs is offline
Default Control 24 problems
Does anyone have any ideas???
My Control 24 is causing my Tannoy active Sub to buzz.
I have spoken to several people at Digi about this and have had no resolutions.
I have tried lifting all kinds of AC grounds,
pin 1 shields, and have also tried tieing pin 1 to chassis and still the same buzz...
It even causes the Sub to buzz when I use chs.3-8 out(the surround outputs).
I can hook up the outs from my other console to the Tannoy active Sub and it is totally clean!
Any suggestions???
Thanks!
Old 04-18-2001, 10:01 PM
lucian lucian is offline
Default Re: Control 24 problems
Before you start doing crazy things like switching grounds and stuff like that ,take in consideration those things. It saved me $5000.00 .
I had some insane ground loops in my system and I didn;t know what cause it until I search on the net and I found an article about separation of diferent devices on the audio chain that has nothing to do with audio. That's after I was almost convinced by a salesman form FURMAN that I need one of those "hi tech power conditioners...bla bla bla
- computer monitors ,TV's , screens, projectors...anything that doesn't have anything to do with sound , that doesn't produce sounds , it should not be in the same power strip with the audio stuff.
-I will unplug - one by one- everything until I may find the source of the "problem" .
-I will plug the sub and the C24 in to another location in the studio and see if it does that .
-If you can get another sub ( rent one , it may cost you as litle as 5$ for a day ) and try it to see if it does the same thing.
If it does is your C24 . If it doesn't is your SuB.
Tha't what I can think for at this oment .
Good luck.
Lucian
Old 04-20-2001, 10:02 AM
Lifedude Lifedude is offline
jkrebs,
I had a simular problem with my C24 only it was a 60 cycle hum in all outputs. It was the power supply in the console and digi just sent me a new console. Problem was fixed.
Big Problems w 10.3.1 on OSX 10.7.4 w D-Control Oakdale Post Pro Tools HDX & HD Native Systems (Mac) 0 11-02-2012 05:56 AM
Control 24 problems Deafeye Pro Tools TDM Systems (Mac) 3 01-08-2007 11:35 AM
problems with control 24 lpfan799 Pro Tools TDM Systems (Mac) 2 08-03-2006 11:19 AM
Control 24 Problems SHAVER ICON & C|24 1 08-22-2005 10:32 PM
Mackie Control problems drewcilla MIDI 2 11-28-2004 10:12 PM
