Old 11-10-2000, 01:36 PM
joey1243 joey1243 is offline
Default Anyway to get 2 mono effects to sync on master?
i'm wondering if there's a way to get (let's say) a compressor on left channel linked to right channel controlled by either 1 and going to the main out (left and right)in pt free. The only way i found so far is using RTAS or whatever its called but thats not real time.
TIA.
Old 11-10-2000, 01:52 PM
Kenn LeGault Kenn LeGault is offline
Default Re: Anyway to get 2 mono effects to sync on master?
Hi joey1243,
RTAS plug-ins are Real-Time AudioSuite plug-ins.
AudioSuite plug-ins (aka AS plug-ins) are the non-realtime, file-based versions of the plug-ins.
It sounds like you want to use a stereo compressor so that the left and right channels are "linked" together. Here's how you can do it.
If you'd like to compress a stereo pair from tracks 1 and 2 (each track is mono, but they form a stereo pair), change the output of each track from the default "out-L, out-R" to "bus 1 - bus 2." Next create a new stereo aux track (use the File/New Track menu and use the popdown list), and set the inputs to be "bus 1 - bus 2." Now put a stereo compressor on the stereo aux bus, and you'll have stereo compression on your tracks.
In an upcoming version of PT (ver 5.1), you'll have an easier way to do this -- there will be multi-channel audio tracks instead of just mono audio tracks. So, you'll be able to create a stereo audio track and record directly to that track. Then, you'll be able to put the stereo compressor directly on the stereo audio track and skip the aux bus stuff.
Hope this helps.
Regards,
Kenn LeGault
Digidesign
[This message has been edited by Kenn LeGault (edited November 10, 2000).]
Kenn LeGault
Director of Software Engineering
Digidesign
Old 11-10-2000, 02:10 PM
wow that was quick ! thanks, thats exactly what i wanted to know. ya i got the file based effects confused i'm new at this! (1st day)
HTML code is On
mono master keenast Tips & Tricks 2 04-13-2011 11:54 PM
Mono Master I/O setup Dean Smith 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-22-2009 06:58 PM
Transfuser on the master fader with ADC enabled makes bpm effects out of sync. Rubicon Virtual Instruments 6 09-25-2008 10:43 AM
mono or stereo aux busses for effects peter99 Pro Tools TDM Systems (Mac) 7 06-20-2006 05:43 PM
Anyway to get 2 mono effects to synch on master? joey1243 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-10-2000 01:34 PM
