Old 10-16-2007, 06:48 AM
rfstudio rfstudio is offline
Default yummy but small issue
Sounds very good. Great variations, easy to use. Really great job guys, kudos to you.
I ran into a small issue where the sound stopped. I was clicking through the amp models sampling the sounds as I was playing and the ALL the audio ceased on the channel with the Eleven plugin. By clicking through to the next model the audio came back. This happened a couple times.
I was running two channels (guitar fed my 002R, to two channels hard panned R-L), with an Eleven plugin and different setup on each. No other inserts etc on those channels. Other tracks played fine when I was in this state.
Food for thought. Great job. I would recommend bundling the LE version with the 7.4 upgrade.
Thanks,
Rick
002R
iMac 10.4.8 2.0 Ghz, 2G RAM, External Firewire 400 drive
PT 7.1.1 LE
Old 10-16-2007, 11:28 AM
Chris Townsend Chris Townsend is offline
Default Re: yummy but small issue
Hi rfstudio, thanks for the kind words. Regarding your techincal issue, the first thing to check is if Error Suppression is ON? If so, you need to turn it off. You might actually be running out of CPU, but with Error Supression you'll just get drop outs instead of an error. Since some amp models use a little more CPU than others this could explain why changing amp types made the audio come back.
002R
PT 7.1.1 LE
Chris Townsend
Guitar Products Architect
Digidesign, A Division of Avid, Inc.
Small video playback issue Meads Pro Tools 9 2 11-28-2010 09:55 AM
small midi issue knetic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-14-2010 07:55 AM
Digi001 in 5 yummy flavors? zavijah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-28-2007 02:32 PM
Small track issue dodo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-19-2005 08:49 PM
Small issue with Waves TDM 3.0 upgrade tld Pro Tools TDM Systems (Mac) 0 11-29-2000 06:30 PM
