Pro Tools 9 error (-9073) HELP
I'm working on Quite a large project in Pro Tools 9 and it keeps quitting after a couple seconds of playback telling me
"DAE cant get audio from the drives fast enough. Your drive may be too slow or fragmented, or a firewire drive could be having trouble due to the extra firewire bandwidth or cpu load (-9073)" The session had been running fine with all the tracks, then it just started acting up. Ive tried decreasing the track count and mix in stems but even with a basic 12 tracks of drums this message is still appearing after a few seconds of playback. I'm running on a macbook pro and ive had the drive checked by apple repair shop and they said that the laptop is working fine with no disk problems. somebody help me please, i'm cracking up. |
Re: Pro Tools 9 error (-9073) HELP
Typical internal Macbook drive is 5400 rpm unless you had the stock drive upgraded to a 7200 rpm drive. The slower drive is an absolute death knell for PT. You really need to give us more info than you have. Complete computer specs (hardware, OSX version, etc.). |
Hi Jack
heres the spec of my mac book its just a stock set up Model Name: MacBook Pro Model Identifier: MacBookPro5,4 Processor Name: Intel Core 2 Duo Processor Speed: 2.53 GHz Number Of Processors: 1 Total Number Of Cores: 2 L2 Cache: 3 MB Memory: 4 GB Bus Speed: 1.07 GHz Boot ROM Version: MBP53.00AC.B03 SMC Version (system): 1.49f2 Serial Number (system): W89399647XJ Hardware UUID: 2701713F-68F6-5157-871C-4E31DD5607BF Sudden Motion Sensor: State: Enabled ive been working off an avid external firewire 400 drive, 7200 rpm. its only with this session im having the problem all other sessions are running fine i'm just wondering if there could be anyway a file in the session could be corrupt and if there was anyway to check for this. If there is any more info required just let me know Thanks for your help. |
All audio or samples and audio? If the latter pulling all that off one drive can cause problems. Also do you have anything else hung off that firewire port (like an audio interface)? It may be running out of bandwidth on the fw buss.
Its audio samples and midi. There is nothing else running of the firewire connection. I used to run my 003 but haven't been using it in this particular situation.Im using a firewire 800 to 400 cable, could that have anything to do with the problem.
Could be - is the drive a fw400 drive? If so get one with fw800 capability and give that a try. Also make sure the drive has the right driver chip in it. Check the Avid site for specs needed.
Is the drive added to the Spotlight privacy list in the system preferences? If not playback can be compromised by the spotlight indexing when you start playback.
Just a thought ..... |
I think you are just choking the computer with VI's. Please note that the suggestions about drives are probably erroneous for the simple reason that you state that this is an isolated session.... that the other sessions are working. I think the "corruption" may be just too many VI's. Deactivate a bunch of those channels/plugins (not bypass) by cntrl+cmmd+click FW400 to 800 adapter cables are fine, and if what you say is true, that you have an "avid" drive.. its an old one, i think. But, it does have the correct chipset. SB |
pro tools SE: error 9073 | miregal | Pro Tools SE and Essential (Win) | 2 | 12-19-2011 10:50 PM |
Pro Tools 8.04 error message # -9073 | ashtonpar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 12-28-2010 10:12 AM |
Pro tools Error (9073) | Finished | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-04-2010 11:34 PM |
Pro Tools LE error (-9073) | 3RD NAIL RISING | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-05-2009 10:44 AM |
pro tools error -9073??? | dbbtexpress | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-31-2007 08:29 AM |
