#21
Re: HDX vs Native
On this particular session it might not have been such a big deal (four trombones, four trumpets and five saxes make so much noise anyway!) but on other sessions the band really seems to appreciate getting a semi-produced sound through their cans. It makes them feel good about what they're playing so I'm always rough-mixing as I go, even as the recording progresses. I suppose everyone does this.
-- Justin Mark Hill https://theotheroperation.com Apple Mac Pro 6,1 late 2013 2.7Ghz 12-Core Xeon E5, 64GB RAM, D500 Graphics, OSX Monterey 12.7.1/Pro Tools Ultimate 2023.12/Presonus Quantum 4848 Thunderbolt 2/Digidesign C|24/Focusrite ISA430 MkII/SPL GoldMike |
#22
Re: HDX vs Native
It seems like to me in hdx the headphone feed sounds correct no matter the playback engine buffer or dsp plugin count. Only time I've had an issue is if a aux channel used as sub master has a bunch of dsp and native plugins. Then the cans sound delayed. But if the sub master just has a dsp limiter or such then it still works fine. I'm usually at 512 playback buffer for vocalists. Changing it to lower buffer doesn't seem to affect latency. So I usually stay at 512 for tracking. I can even punch in on a track with a mix of dsp and native plugins. If the native plugs are first in the chain. They just get disabled at record and input.
For hdx tracking it pretty much set it and forget it. As long as you use aax dsp. No worry about anything else. Sent from my SM-G975U using Tapatalk |
#23
Re: HDX vs Native
I've used them all dont get me wrong.. but it is still a matter of math to calculate the roundtrip latency. With zero plugins the difference is in the hardware. Add first native plugin and it's about the playback hardware plus buffer. Add first DSP plugin and it's the former plus DSP latency.
Whatever track-it-as-you-mix session I have ever had, the DSP latency has always been about 350 samples or more, although trying to be conservative. That is already +7ms @48k not taking ADDA into account. So great if you have DSP and some of your goto plugs have lower latency on hardware (lowest i've seen on TDM were 3 or 4 samples) compared to native, but the fact is if you have ONE native plugin on DSP system you will also have playback buffer latency. Hardware + Playback + DSP = total latency.
#24
Re: HDX vs Native
Sweet. Also my experience on native systems since 2002 have been similar if you set playback buffer to 256 or lower. To repeat myself, 256 playback buffer makes "headphone feeds sound correct"
#25
Re: HDX vs Native
Couldn't agree more. So I never use any native plugins on tracking sessions.
#26
Re: HDX vs Native
Assuming same hardware of course. And assuming any given native plugin isn't introducing insane amount of delay (which is rare, because same plugin on AAXDSP should be faster).
#27
Re: HDX vs Native
Yes for tracking it still is great, with DC’d outs and zero (perceptible) Latency on the in’s. And no 3rd party software hoops to jump through, sends from the PT mixer It’s a one trick pony but that trick is very nice.
#28
Re: HDX vs Native
#29
Re: HDX vs Native
#30
Re: HDX vs Native
I know, some divas are even sensitive to the temp of drinking water they are being served.
Nevertheless, HDN rtl 96k@128 buffer is 3ms (don't remember who measured this but thanks anyway) which is pretty darn good. I still use my trusty old HD rig on live gigs and never ever my real life mixer has less than 350 samples of DSP latency (@48k) which means +7ms just for processing plugins. I have never had HDX of my own so don't have any numbers for it. Latency is only noticeable when it's too much; you either can monitor or you cannot. But sure, if you have a bad day changing that drinking water to colder one may make your guitar solo shine. I understand that.
FS: McDSP Analog Channel Native V5, 6020 Ultimate EQ Native V5 | soundroad | Buy & Sell | 31 | 03-21-2016 06:03 AM |
Does HD native or native native disable plugins when monitoring inputs? | BasketCase | Pro Tools HDX & HD Native Systems (Mac) | 7 | 05-20-2013 08:48 AM |
FLUX Elixier V3 AAX Native & DSP + Freeware Bittersweet V3 AAX Native & DSP released | psmworld | AAX Plug-ins | 18 | 01-31-2013 04:16 PM |
SSL4000 native/ Renmaxx native/ DUY everpack native!!! | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-22-2007 07:58 AM |
