Old 09-26-2017, 02:59 PM
cruisemates cruisemates is offline
Default Re: Asio issue Eleven Rack wont initialize
I run a Digi003 and an 11-Rack. I only want the 003 as my main interface, so I make sure the 11-R is turned off when I boot up and start Protools. That way it is always the interface that PT sees.
I then turn on the 11-R after I am booted up & PT is started, and I can use it as a standalone on a given channel.
Whatever you want to use for your interface - make sure it is connected and turned on when you boot up and when you start PT. FYI, I have found that if both are turned on it will not see the 003, and will load the 11-R as the default.
- but the second mouse gets the cheese
Eleven Rack Issue JimmyD150155 Eleven Rack 0 12-06-2015 02:08 AM
Eleven Rack Firmware wont activate!! Frettin Freddy Eleven Rack 2 04-08-2014 06:59 AM
Issue with i/o after eleven rack use jimbridgman Eleven Rack 2 02-11-2014 09:14 PM
Pro Tools 9 wont initialize ASIO driver for Realtek HD audio device and more fireal2112 Windows 19 05-05-2011 11:16 PM
Eleven Rack with HD issue Touchwood Studios Pro Tools TDM Systems (Mac) 6 10-09-2009 12:22 PM
