nero wont burn pro tools 002Rbounced tracks
hi guys
when i bounce my tracks down to stereo on my 002R i cant burn the wav files in nero, however when i import the tracks to cubase sx and export them from there they burn no problem any ideas? |
Re: nero wont burn pro tools 002Rbounced tracks
What is the format you bounce down to?
Might be something wrong there, like you selected 48K instead of 44.1 and in Cubase you didn't? |
It's a known issue that Nero doesn't like some of the information that PTLE puts in the header of its wave files(somebody correct me if I'm saying it the wrong way or so). The trick you perform is a variation on what's usually done to work around it. You can also open your bounces in Wavelab or Soundforge and save them from there, and you'll be fine. Good luck,
Voideco
Mac Book Pro 2016 Retina, Quad core i7, 2,5 GHz, 16 Gb 1600 MHz RAM, 256 SSD drive, 500 Gb SSD USB3 OSX Sierra 10.12.5, PT 12.7.1, UVI Falcon 1.6 Metric Halo ULN8 3D Interface, NI Komplete Control S49 midikeyboard Macbook Pro M1, 2.5 GHz 8 core CPU, 32 Gb RAM, 1Tb storage, Monterey 12.6.6. PT Ultimate 2023.6, UVI Falcon 3.0 + some soundbanks, Waves Platinum bundle, some free Melda plugz, Metric Halo/Make Believe plugz. |
Hi FinnJ,
1)Does Nero burn CDRs from other applications ? 2)You must specify "stereo interleaved" for your bounced/exported files . PT by design uses dual mono (*.L & *.R ) designation for stereo files. I dont think Nero can handle those. 3)CDA is always 44.1 kHz, 16 bit. >>convert after bounce happy tooling,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
I believe they fixed Nero in the newer versions to not choke on unknown header data. Update your version of the software.
Rail
Nero 5.5.5.6 won't burn wav files from LE 6.4.. | dubs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-02-2004 10:12 AM |
Session Archiving - Nero won't burn disc | blizzard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-25-2003 11:23 AM |
Nero won't burn WAVs | guy.fi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 02-04-2003 05:53 AM |
Nero can now burn wav's from ptle!!! | Bastiaan | Digidesign Hardware & Software | 3 | 09-09-2002 06:36 PM |
Nero can now burn wav's from ptle!!! | Bastiaan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-08-2002 01:20 PM |
