Old 08-13-2003, 04:38 AM
Adrian D Adrian D is offline
Default sync midi drum tracks to wav tracks
I am running 6.1 and recorded wav information for toms, snare and kick from a Clavia Ddrum4 with live cymbals and hi hats. I also recorded the midi information. Well the drummers track was a little choppy so I want to use the midi tracks. When I quantize the drums, they are out of timing with the audio cymbals. I think the delay is on the midi tracks. What is the best way to take advantage of the midi functions like quantize. Do I nudge the audio cymbals to match the quantized drums or if I nudge the midi drums to match the wav cymbals. If I nudge to the cymbals will I lose the ability to quantize based on true time in the grid? Is there a way to calculate the offset or is that just a hit and miss kind of thing you just need to keep playing with?
Thanks for the help!
Old 08-14-2003, 12:24 AM
metaltim metaltim is offline
Default Re: sync midi drum tracks to wav tracks
if everything is lined up to the grid except for midi, then by all means, move the midi to the audio, not the audio to the midi..
there is something called global midi offset. It does what it says, offsets all midi notes/tracks by a specified amount..
i believe it is in preferences under midi..
hope that helps
tim
drum/midi tracks? Intelli-Shred The Drum Room 4 02-27-2012 11:21 AM
How sync up imported drum tracks barketta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-21-2005 08:25 AM
How to Sync imported drum tracks barketta Tips & Tricks 0 02-19-2005 11:05 AM
How Do I Sync Midi Tracks and Audio Tracks Antonio Tarantino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-11-2003 05:49 PM
MIDI Drum Tracks in PT NormCouturier General Discussion 1 11-15-2000 09:30 AM
