Old 02-22-2002, 06:46 PM
dummy20707 dummy20707 is offline
Default What is Q in a parametric?
You can cut the highs, or cut the lows. Parametric lets you cut (or boost?) a hole in the middle right?
Q adjusts the size of the hole right? Regarding the EQ that is on Pro Tools, is a larger Q number a bigger hole or smaller hole or what?
Old 02-22-2002, 06:51 PM
Cinemafixer Cinemafixer is offline
Default Re: What is Q in a parametric?
the higher the Q, the smaller the BANDWIDTH of boost or cut
Old 02-22-2002, 07:22 PM
hongz1 hongz1 is offline
Q (Quality factor) is a ratio of center frequency to bandwidth.
Q = Fc / B = Fc / (F2 - F1)
For example, if center frequency is 141Hz Bandwidth is 100Hz (100Hz ~ 200 Hz) Quality factor will calculated as refer to "1"
Measurement in Q (b/c it is Ratio)
Therefore, the narrower bandwidth, Q is increased, that means you can cut or boost more specific frequency range.
Peace [img]images/icons/grin.gif[/img]
Old 02-22-2002, 08:03 PM
Jorge442 Jorge442 is offline
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by dummy20707:
is a larger Q number a bigger hole or smaller hole or what?<HR></BLOCKQUOTE>
smaller
what a long, strange trip it´s been
www.abacomusic.com
MDW Hi-Res Parametric EQ Demo MatthieuH RTAS & TDM Plug-ins 6 12-05-2013 04:54 PM
MDW Hi-Res Parametric EQ v5 is now available Avid Technical Alerts 1 08-24-2012 12:55 PM
More 11R Parametric EQ settings Deny Eleven Rack 6 06-24-2011 06:00 AM
parametric output EQ krishkrasj VENUE Live Sound Systems 1 05-10-2010 12:48 PM
All Digital Parametric EQ’s are the same muesli Pro Tools TDM Systems (Mac) 1 01-27-2010 07:50 AM
