HELP ! ! PowerBook G4 error Type 3, Type 2 HELP ! !
[img]images/icons/confused.gif[/img] [email protected] Greetings all. . .Anyone out there using pro tools LE 5.2 on a powerbook G4 800mhz ? ? I keep getting error type 2 or type 3 messages. . .What do i do ? ? I have tried memory allocation, reinstalling os9 (clean install...i have done that twice and each time it works for a bit and then screws up a day or two later )
Digidesign says that it is a system error not cause by pro tools...but since everything worked fine with os9 before i got protools and since protools is the only program on there. . I have a hard time believing that. I have also tried finding the conflicting extentsion but to no luck...Does anyone know of any known extension conflicts ? ? I downloaded both the mbox firmware updater, and the digidesign Usb driver..and installed those..,. It seems to me that i have tried everything, I have reinstalled pro tools so many times that i am starting to think i could be screwing with the hard drive....I can be loading the program, or tring to use a plugin in the mix window...or pressing the return key to take me back to the beginning....any of these things can cause an error and more . . . If anyone knows anything about this little problem please contact me asap...Any comments are appreciated....Peace B |
Re: HELP ! ! PowerBook G4 error Type 3, Type 2 HELP ! !
You may try trashing all your Digi prefs including the DAE...you could also try a DUC search for this forum...
A Blues Harp and PowerBook is all I need ... along with Analog Signature Pack & BlueTubes 3.0 !! |
are you by chance using an external FW Lacie hd?
CHUCKNKD [url=www.myspace.com/chuckbutlermusic[/url] |
Best AMD motherboard slot type / cpu type / etc. | SixChurchStreet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-19-2007 06:29 AM |
Error type 2 | Lol Levy | Digidesign Hardware & Software | 12 | 02-01-2002 06:08 PM |
Type 3 & Type 2 errors randomly | Q | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-30-2001 05:26 AM |
Error Type 2 & 3 | Dr. J | Pro Tools TDM Systems (Mac) | 2 | 03-02-2001 05:55 AM |
PT Mix 4.3.2 +Midi Playlists = Type 2 & Type 1 crashes | Lewis Ross | Pro Tools TDM Systems (Mac) | 1 | 11-09-1999 07:03 PM |
