Old 01-09-2024, 01:41 AM
patrem93 patrem93 is offline
Default X-MON and stereo inputs
hi,
I have the xmon to which I would like to connect two stereo sources. in the manual, I clearly understood that I had to use the stereo inputs 1-2 (L-R) and 3-4 (L-R) , but this is the only DB25 for which there is no the connection diagram on the pins? is the same wiring as for the cue inputs socket
1 pin 24-12-25 Left
2 pins 10-23-11 Right
3 pins 21-9-22 Left
4 pins 7-20-8 Right?
Thanks for your help
Best upgrades from Paris
Patrick
Old 01-12-2024, 05:16 AM
Third Eye Studios Third Eye Studios is offline
Default Re: X-MON and stereo inputs
Originally Posted by patrem93 View Post
hi,
1 pin 24-12-25 Left
3 pins 21-9-22 Left
Patrick
Yes, the wiring is the same, you are correct on the pins used.
Alternatively, you could connect your first stereo input to channels 1 and 5 on the Main Input DB25, and be able to connect 4 stereo inputs total.
The old DCommand Manual shows the pin configuration for all the DB25s.
Old 01-13-2024, 07:27 AM
Thank you very much for taking the time to answer me Sincerely
Need help converting 4 stereo Adat inputs to 8 mono inputs. johnbarnesiii macOS 2 11-24-2019 02:04 PM
XMON Stereo Inputs WildHoney ICON & C|24 8 06-27-2016 10:27 PM
using stereo inputs francois ICON & C|24 1 07-04-2012 09:52 PM
Can this be? Only 16 stereo inputs in PT9? MacPC Pro Tools 9 98 03-22-2011 08:53 AM
MBOX PRO 2 STEREO INPUTS!!??? houseofoaktree 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-03-2007 11:18 AM
