Old 06-22-2022, 10:15 AM
Mixmaster Rick Mixmaster Rick is offline
Default EuCon Not Working macOS Monterey
All,
I had been using macOS Catalina on a MacBook and my Pro Tools 2022.4 environment with EuCon worked perfectly fine.
This week I purchased a Mac Studio (M1) and installed Pro Tools 2022.5 along with EuCon 2022.4.0.78 and have been unable to get anything done. I have tried reinstalling EuCon, uninstalling and repeating yet whenever my computer restarts post installation EuCon seems grayed out. I get the message to add at least one surface (I have a Dock and 2 S1's) and while they appear in All Surfaces I am unable to Add or Remove them.
Can you please help?
Pro Tools Studio 2023.12.1, Mac Studio 2023 M2 Ultra, 64GB RAM, macOS Ventura 13.6.4 (22G513), UAD Apollo X8, Apollo x6 (2), UAD-2-Satellite-TB3-Octo, UAD-2-Satellite-TB3-Quad, Avid Dock w/ iPad Pro 12.9", Avid S1 (2) w/ iPad Air 10.9", Neumann KH 310 w/ KH750 Sub, Genelec 8320A, Adam Audio T7V w/ Sub8, G-Technology TB3 x 6
Old 06-22-2022, 11:37 AM
dominicperry dominicperry is offline
Default Re: EuCon Not Working macOS Monterey
I only use an iPad with EuCon but the following works ok:
Mac:
MBP M1 Max 16" on Monterey 12.5b3
PT 2022.5
EuCon 2022.4.0.78 (EUCON Version 4.8.6.78)
iPad:
iOS 15.5
EuControl 2022.4.0.60
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 06-23-2022, 09:31 AM
eightamrock eightamrock is offline
Originally Posted by Mixmaster Rick View Post
All,
So I dont have any eucon interfaces directly connected over ethernet, but I have had a lot of issues getting eucon to work with my ipad and the control app. The best fix was setting up a separate wifi network that was not multiband, but 5Ghz only and connecting my computer and my ipad to it. Eucon has worked well ever since.
Old 06-23-2022, 01:30 PM
For whatever reason EuControl lost all of my surfaces so I started with a power down then up and it detected the Dock and two S1's. At this time I'm up and running again. I'm seeing several weird things with macOS Monterey though...
Old 12-07-2022, 04:30 PM
bemelodic bemelodic is offline
Everything was working fine until 2 days ago.
Eucontrol shows Artist Mix both in "All Surfaces" and "My Surfaces". In PT I have EUCON enabled in Peripherals.
I don't get any connectivity on the mixer. As though it knows it exists but can't communicate. So the screens are blank with exception of the pan bar. Faders down all the way.
I've tried rebooting, uninstalling EUCON, reinstalling it. EUCON is listed in the accessibility under the OS security settings.
Computer and Artist mix are connected to switch via Cat5e.
Hardware:
2022 Mac Studio M1 Max; 32 GB.
Avid Artist Mix
Netgear 5-port un-managed switch
AT&T Fiber Router
Operating System:
macOS Monterey 12.6.1
Pro Tools 2022.10
Old 12-07-2022, 05:23 PM
Eric Lambert's Avatar
Just for some added info, that era of PT and EuCon wasn't great for me either but the more recent versions have been pretty solid. EuCon does occasionally lose my iPad but restarting the iPad Control app fixes it so that seems to be an app issue. I'm also using an M1 w/ Monterey, fwiw.
Old 12-08-2022, 03:16 PM
James Steele's Avatar
James Steele James Steele is offline
I'm on a M1 Max Mac Studio with Monterrey 12.6.1 and using an older Euphonix MC Control and MC Mix that is flashed with latest Avid firmware, and both units are working well here. Not sure what to suggest, but it is working here. I hope you find where the problem is and can fix it.
Old 12-08-2022, 10:35 PM
The original silver ones? I have one of each but they won't connect anymore. I've not done anything to the firmware in over a decade however. I'm curious about this Avid firmware of which you speak.
Old 12-09-2022, 12:33 AM
Yes, the old Euphonix branded silver ones. I downloaded the latest Eucon Unified installer and ran it and I think when you launch EuControl and/or select your device it will prompt you if you need to update the firmware. If you haven't updated firmware in a decade than it's may very well be the problem.
You need to go to the "Download Center" here:
https://my.avid.com/esd/Product/Information/113
... and download the EUCON Unified Installer from Sept 15, 2022. It's right near the top. Install that. I can't remember the exact steps but at some point in the process, if your units are connected to your Mac, you will be prompted to update the firmware in the attached units.
Old 12-09-2022, 05:52 AM
made made is offline
I had weirs stuff going on with Eucon out of the blue.
Support helped me with a solution:
- download the latest installer
- check uninstall options and run (un)installer
- restart mac
- reinstall Eucon
- restart mac
hope that helps
Mac Studio, 32GB, PTHD2022.7, OS 12.5.1, S3, Transport, (EuCon 2022.4.0.78)
LIO-8
BlackmagicDesign UltraMonitor3G
Reaper 6.66, Fireface UCX
MacbookPro M1Pro PTHD2021.12 MacOS12.1
MOTU 24Ao AppleTB3toTB2->AppleTB2->Ethernet->AVB
Mbox not supported by MacBook pro MacOS Monterey 12.x Maripersen Pro Tools 12 4 09-17-2022 09:24 AM
Avid Quartet and macOS Monterey gng75 Pro Tools | Duet & Pro Tools | Quartet 0 04-24-2022 05:41 PM
macOS Monterey 12.3 officially supported! DerrickC Pro Tools 62 04-01-2022 01:31 AM
Mbox3 pro MacOs Monterey SIP suggested Madsvigeholm macOS 5 12-28-2021 09:25 AM
