Old 10-27-2018, 10:54 AM
Izidro Izidro is offline
Default Ambisonic Audio in PT2018
I am a sound designer/engineer who is just beginning to work with Ambisonics, do I have to purchase a PT Ultimate licence in order to get quad tracks in Pro Tools? The Ultimate licence is a bit steep for me at the moment, does anyone have another solution?
Old 10-27-2018, 11:16 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Ambisonic Audio in PT2018
Yes.
Pro Tools Comparison Chart
You could set up your tracks and I/O to playback over 4 speakers using volume faders as panners, but I don't think you'll be able to mixdown to a quad track. Plus, it's really awkward to work that way without a surround panner.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 10-27-2018, 11:39 AM
ok, thank you for the quick reply guys, I guess I will have to open the wallet =(
There is no point migrating to Reaper, Nuendo is just as expensive and Logic really sucks...so...
Anyways, thank you very much
Old 05-15-2019, 02:17 PM
Mark Mangini Mark Mangini is offline
I am using the new PT 1st order Ambisonic tracks to create B-Format masters from my A-Format field recordings. I use VVEncode to do the B-Format encoding on a 1st order track that contains the audio. I then bus that output to a second 1st order PT record track to make the B-Format master. Trouble is this: anything recorded on a PT 1st order Ambisonic track is stamped with unreadable track order metadata. I know this because when I try to import something I have recorded on a PT 1st order track, I cannot preview it with IMPORT audio NOR will Quicktime play it, NOR will my library browsing program play it. When I do a "GET INFO" in Quicktime on a file recorded on a 1st order track, the FORMAT field has ???? marks (see below) where the channel layout should be. Is this a PT bug? Am I using the wrong signal path? The only solution I have found is to copy the new B-Format recording to a Quad PT track and DUPLICATE the audio, thereby rendering a channel layout that PT, QT and others can read. Curious to hear what others have found.
http://duc.avid.com/images/attach/png.gif
File Type: png Screen Shot 2019-05-15 at 12.44.36 PM.png (46.3 KB, 0 views)
PT2018.7 - Win 8.1 or 10? PhilSMusic Pro Tools 2018 5 08-06-2018 12:19 PM
New SFX Library: DL0118 Downtown Los Angeles Ambisonic Library Vol 1 myke2242 Post - Surround - Video 1 03-30-2018 05:51 PM
Ambisonic Plug-ins for 12.8.2 Kewl AAX Plug-ins 3 12-04-2017 08:22 AM
Surround (ambisonic) mixing in LE McGriffy Tips & Tricks 3 08-25-2001 09:28 AM
