Old 11-10-2002, 05:03 PM
gmcgmusic gmcgmusic is offline
Default Macos X
I currently run LE 5.1 on a G4. I have aquired OS X and want to use it as it looks and seems great. At the moment I'm running 9.1. Can anybody give me advice on how to run OS X and continue to use 9.1 for running protools, like how to start it and wot i need to do???
Old 11-10-2002, 05:48 PM
slickrick slickrick is offline
Default Re: Macos X
If you re-format your internal HDD (from the Mac CD-ROM), you can partition it into 2 or more drives.
The install OS9 on one, and OSX on another.
All you then do to change between OS's is select Control Panels > Startup disk to change it.
Be warned: don't try and launch ProTools in OSX classic....I tried out of interest, and it fked Tools, requiring a re-install.
Rick
Old 11-10-2002, 07:15 PM
where02190 where02190 is offline
Default Re: Macos X
There is no need to reformat or partition ot run OSX. Simply install OSX on your system drive. To boot into OSX from OS9, go to Control panels-star-up disk-select OSX and restart. Your computer will boot into OSX. To return to OS9, to to system preferences, select OS9, save and restart.
There are many happy mac users (including us) that run OSX and OS9 on the dame drive and partition with absolutely no problems.
Also, FWIW, reformatting (AKA reinitializing) your hard drive will destroy all data on the drive, meaning you will have to reload OS9 and all appliations you currnetly have loaded, and you will loose all your files.
Hope this is helpful.
Old 11-11-2002, 04:22 PM
Schmee Schmee is offline
Default Re: Macos X
I know you can have OS X and OS 9 on the same partition as I did for a while with out any problems.
However one advantage of running them on 2 sperate partitons is that you can use the boot menu (just hold the Alt/Option key) which I have found usefull if I have just turned the mac on and want to go into 9 without the hassel of loading 10 first.
Just my $0.02
Lee [img]images/icons/smile.gif[/img]
P4 2.8
1Gb RAM
XP Home
PT LE 6.1.1
Digi 001
Old 11-11-2002, 05:38 PM
staedtler staedtler is offline
Default Re: Macos X
that's why i have os x and os 9 on two seperate drives..
but the option key doesn't work [img]images/icons/confused.gif[/img]
it get to the screen with the options but
it won't do anything when i choose a drive [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img]
so what's up with that?
anyone?
well... i just choose from the start up disk menu now..
no hassle since i really don't turn off my computer...
but once in awhile i do.... i hate waiting... [img]images/icons/grin.gif[/img]
k.
Old 11-12-2002, 03:09 AM
propstuff propstuff is offline
Default Re: Macos X
<font size="2" face="Verdana, Arial">did you hit enter after you chose the drive option?
nicholas.
TiBook 550MHz
OS9.2.2
PT5.2
400Mb allocated
Old 11-12-2002, 09:25 AM
Default Re: Macos X
that would be embarrassing [img]images/icons/blush.gif[/img]
but yes i did... everytime...
it just sits there... [img]images/icons/confused.gif[/img]
k.
6.0 and Macos X gmcgmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-11-2003 09:08 AM
MacOS X is getting old... Samuelsson Pro Tools TDM Systems (Mac) 0 03-07-2002 11:09 AM
MacOS 9.2.1 Slaterman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 08-30-2001 11:28 AM
MacOS X ilnegro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-26-2000 10:03 PM
PT TDM 4.3.1 on G4-AGP w/MacOS 9.0.4? Dzerdzinsky Pro Tools TDM Systems (Mac) 3 06-22-2000 12:40 AM
