Old 02-01-2018, 06:22 PM
jre3132 jre3132 is offline
Default Distortion during compression/limiting
This is driving me crazy....Anybody else having this issue???
12.8.2 was great. Now with 2018.1 (and also with 12.8.3) when I add a compressor or limiter, any processing that they do comes out as distortion. It is consistent with all different makes (waves, avid/digi, mcdsp, etc). The more processing the more distortion. It really shows up terribly with the L2 and ML8000 on the master buss. If I revert back to 12.8.2, it goes back to normal.
Admittedly I was under on RAM when I tried to upgrade to 12.8.3 the first time. I thought the lack of memory might be straining/under-processing and causing this bug. However, now I've maxed out the RAM my Mac and am above the minimum requirements. I don't know what else to do.
Mac Pro 3.7 Quad Core Intel
Mac OS X 10.13.2
PT Ultimate HDX 2019.10
64GB RAM
HDX I/O 16x16 Analog
HDX I/O 8x8x8
Old 02-02-2018, 07:35 AM
john1192 john1192 is offline
Default Re: Distortion during compression/limiting
test in a clean blank session with ONe Track made in the version of your choice .. if it still happens then open a support ticket ..
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 02-02-2018, 02:41 PM
Spent a couple of hours on the phone with tech support today. Nothing seemed to work. He decided to check the firmware on the HDX IOs. There was not an update and they were running the current version. We ran the updater and let it reinstall the same version over just to refresh the existing version. That seems to have fixed the issue.
Just figured I'd post the solution that worked for me just in case anyone else had the same issue.
Mac OS X 10.13.2
64GB RAM
HDX I/O 8x8x8
Old 02-03-2018, 08:13 AM
good to hear you are back up and running distortion free !!!
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Normalizing vs Compression or Limiting barismanco123 Tips & Tricks 17 01-23-2009 11:08 AM
Compression/limiting after encoding hef Post - Surround - Video 4 05-14-2008 08:03 AM
6.1 Compression & Limiting derF Pro Tools TDM Systems (Mac) 1 05-20-2004 12:34 PM
Limiting and compression. Garry Taylor Pro Tools TDM Systems (Mac) 4 04-26-2002 07:32 AM
Compression and Limiting - External DSP choctop Digidesign Hardware & Software 1 03-28-2001 01:07 PM
