Old 10-27-2016, 03:51 PM
Jerry.VC Jerry.VC is offline
Default macOS Sierra Approved
Drivers are out also. Anyone encountering any problems?
15" Mid 2014 Retina MacBook Pro i7 2.2ghz 16gb Ram 256 Flash
Pro Tools 12.6 11R
EQP-WA, WA76, Daking Mic Pre One
Old 10-27-2016, 08:12 PM
Default Re: macOS Sierra Approved
It is good to get the final approval. I've been running PT 12.6 on Sierra for a few months on my test system with only a problem with the MiniGrand instrument. Now I feel safe to update the OS on my production systems.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 10-28-2016, 08:55 AM
Jeffrey Talbot Jeffrey Talbot is offline
Problems? Yes.
With a very fresh install of 10.12, Sierra, and a very fresh install of PT 12.6, it just plain doesn't run.... at least for me.
Old 10-28-2016, 10:29 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Just completed my second clean install-setup
Avid Waves, Native instruments, Play, McDSP all in good shape.
Melodyne, Reason, Notion, DP add on also in fine order.
What's your system Mr. Talbot?
Old 10-29-2016, 03:08 PM
off the wall's Avatar
off the wall off the wall is offline
Is 10.12.1 approved?
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 10-31-2016, 09:38 AM
Trashcan MacPro, PT HDX. TB Chassis from Sonnett. Sierra and PT 12.5.x works fine, so I'm guessing PT12.6 SHOULD work.
At this point it's easy enough to start over.
Old 10-31-2016, 01:49 PM
treason treason is offline
I've got increased CPU usage as well on Sierra 10.12.1 compared to my EC 10.11.6 partition. The EC partition had the updated PT HD driver, was cloned, and Sierra 10.12.1 was installed on my 2012 12 Core Mac Pro.
What I believe is plugins are the difference between issues vs no issues on Sierra. I've got a bunch of Plugin Alliance plugs, and they are not Sierra approved. I can't seem to find a list of Sierra approved plugs.
T-
Waterstreet Studio Main: MacPro 2012 ([email protected]), 48GB, Apple/Samsung SSDs, WD Blacks. macOS 13.3
DSP & IO : Pro Tools HDX2(2018.3), 2x UAD Octo, HDIO 16x16 Analog IO(3), HDIO 16x16 Digital IO
Plugins: Avid, DMG Audio, Kush, oeksound, P'n'T, Plugin Alliance, Softube, SoundTheory, Sonnox, Sound Radix, SoundToys, UAD, VEP, etc
Hardware: API, Chandler, Hardy, Moog, Neve, Shadow Hills, Smart, Summit, TC Electronic M6000, UREI, etc
Microphones: Telefunken, Neumann, Shure, AKG
Old 10-31-2016, 03:12 PM
PhiBee's Avatar
PhiBee PhiBee is offline
I though it was only AU version concerned with Alliance issues. I'm using AAX bx_meter and bx_rockrackV3 (for example) without issue at all under macOS Sierra 10.12.1 and PT12.6.
WIP house Prod - home studio
iMAC - Pro Tools Ultimate 2022.6 - RME Digiface USB - Audient iD22 - Behringer ADA8200 - Digidesign C|8 - NI KK A61
STUDIO PRO Post-prod
MAC Pro "Trash can" - Pro Tools HDX + Ultimate 2021.12/Avid C|24/S3/ProTools|Dock. Blackmagic.
Old 10-31-2016, 08:44 PM
Their website makes a general "we do not support Sierra" (see attachment) claim in their customer support section. I use alot of their plugins in AAX-DSP and AAX-Native. I am seeing performance hits opening the same session in Sierra vs EC 10.11.6. It may be another culprit, but plugins have been the past issues for a vast number of issues with PT since v11.
It's great that you're not having issues, and I expect to join that club soon.
File Type: jpg Screen Shot 2016-10-31 at 8.39.11 PM.jpg (24.8 KB, 0 views)
T-
Old 11-04-2016, 09:58 AM
So just for fun I started over.
Newly erased HD, fresh install of Sierra, did all the OS updates, then went to Avid, and downloaded PT 12.6, and installed the app, as well as the HD driver.
Since my HDX card is in a TB chassis, I just connected the chassis to my MacBookPro, added the iLok, and ran PT. While the app does work, it doesn't see the HDX card as a Playback Engine option. My TB chassis also has a FW card, and attached to that card is a Mackie FW mixer, which PT DOES see as a Playback Engine option, so this is not an issue with the chassis, but seems to be a problem with 12.6 and HDX.
macOS Sierra 10.12 now supported with Pro Tools v12.6 Avid Technical Alerts 0 10-26-2016 12:29 PM
PT on macOS Sierra? eesn Pro Tools 12 66 10-01-2016 11:46 PM
No video lag with PTHD 12.5.2 on macOS Sierra soybalm Pro Tools 12 3 09-25-2016 10:46 AM
macOS Sierra 10.12 not yet supported Avid Technical Alerts 0 09-20-2016 10:34 AM
