MacOS X
Hello everybody!
A simple question: if I upgrade from MacOS 9 to MacOS X, will I have problems with Digidesign software? Thank you and Merry Xmas! |
Re: MacOS X
OS X will run current sessions through OS 9.04 but not until the real OS X's release and Digi updates PT. But Digi is already updating PT to run under OS X so, you may not need OS 9, as long as you can wait, which I'm hearing is probably at Mac Expo Tokyo in Feb. 2001.
Armando |
Re: MacOS X
it will be doable only once the OSX has been implemented by Digidesign software. So far, OSX is not Digidesign compatible as far as I know, so the answer to your question is likely a-big-fat-yes(!), if you upgrade now, then you will have problems with OSX.
------------------ -AT Absorb what is useful, reject what is useless, and add what is specifically your own. ~ Bruce Lee |
Re: MacOS X
Thank you for your advice Mr. Analog Tree! I'll save some 40 bucks for something more useful!
Re: MacOS X
OS/X has a layer which will allow it to run current applications. I would not try it until you hear how stable the results are.
Re: MacOS X
Pioneers get the arrows...settlers get the land.
Re: MacOS X
Sorry. Current versions of ProTools will not run under OSX -- the "Blue Box" compatability mode does not allow access to PCI (and thus our HW).
Not to worry -- we are *definitely* working on an OSX version of ProTools . . . -- Joe Digidesign Engineering |
Re: MacOS X
That is good News. Thanks Digi.
Nick |
6.0 and Macos X | gmcgmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-11-2003 09:08 AM |
Macos X | gmcgmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-12-2002 09:25 AM |
MacOS X is getting old... | Samuelsson | Pro Tools TDM Systems (Mac) | 0 | 03-07-2002 11:09 AM |
MacOS 9.2.1 | Slaterman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 08-30-2001 11:28 AM |
PT TDM 4.3.1 on G4-AGP w/MacOS 9.0.4? | Dzerdzinsky | Pro Tools TDM Systems (Mac) | 3 | 06-22-2000 12:40 AM |
