Re: Pro Tools 10.3.4 MASSIVE Crash Errors
Try running the Pro Tools installer again. Chris
Thanks for replying, albee!
Unfortunately, it crashes when loading from the icon, and I'm totally out of fixes. I've tried uninstalling and reinstalling; Ive trashed the preferences and DAE folder; I've repaired permissions... Pro Tools crashes when looking for the 'VariFi.dmp' plugin. |
Hi again, Chris!
I've run the Pro Tools installer again, and Pro Tools is now crashing when looking for 'VariFi.aaxplugin'. I've uninstalled 10.3.8, and have now reinstalled version 10.0 I am not seeing any of the fatal error warnings, but the error script is reading much the same as it was earlier on. I've trashed my preferences and DAE prefs, have uninstalled and reinstalled the software, and I'm stuck on what to do next. |
Could you post a full crash report, including all threads etc. If its too long for a single post, post across two posts. The most likely cause of crashes, and the first thing to exclude is third party plugins any non-core Avid plugins. Are all plugins up to date? Compatible with this Pro Tools and OS X version? Try moving all third party plugin files out of the RTAS and AAX plugin folders and start Pro Tools and see if this problem reoccurs. See http://www.pro-tools-expert.com/home...d-running.html for plugin locations and general good advice. It was suggested before in this thread to remove plugins files from their folders (not just trash prefs and databses) was this done? What happened? |
Hi Darryl,
Thank you for your time. As you had stated, it was mentioned earlier in the thread to approach the problem from the plug-ins front. I've done just that, attempting to weed out which plug-in it is (or could be) that is causing the error. Not a thing changed with this approach. Pro Tools is still cutting out when it begins to search for 'VariFi.dmp'. I have removed all third-party plugins from my hard drive. Here is the crash report: Process: Pro Tools [521] Path: /Applications/Avid/*/Pro Tools.app/Contents/MacOS/Pro Tools Identifier: com.digidesign.ProTools Version: 10.3.8.378 (10.3.8f378) Build Info: Unknown-10380378~378 Code Type: X86 (Native) Parent Process: launchd [140] Date/Time: 2014-01-13 18:42:30.759 -0600 OS Version: Mac OS X 10.7.5 (11G63b) Report Version: 9 Interval Since Last Report: 323804 sec Crashes Since Last Report: 104 Per-App Interval Since Last Report: 493 sec Per-App Crashes Since Last Report: 41 Anonymous UUID: C0C675C3-6C7C-46DC-ADD4-7CCDA21313FB Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_ACCESS (SIGBUS) Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000 VM Regions Near 0: --> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Applications/Avid/*/Pro Tools.app/Contents/MacOS/Pro Tools __TEXT 0000000000001000-0000000000143000 [ 1288K] r-x/rwx SM=COW /Applications/Avid/*/Pro Tools.app/Contents/MacOS/Pro Tools Application Specific Information: objc[521]: garbage collection is OFF Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 com.apple.CoreFoundation 0x945ea921 CFStringGetLength + 17 1 com.apple.CoreFoundation 0x94606002 CFStringFind + 18 2 com.digidesign.framework.DAE 0x0c1cb17e FicMain + 48414 3 com.digidesign.framework.DAE 0x0c1ccf34 FicMain + 56020 4 com.digidesign.framework.DAE 0x0c1d30a7 FicRegisterDirectMIDIClient + 1735 5 com.digidesign.framework.DAE 0x0c27802d FWMidiCallback + 231133 6 com.digidesign.framework.DAE 0x0c2799f8 FWMidiCallback + 237736 7 com.digidesign.framework.DAE 0x0c2de3cc FWMidiCallback + 649852 8 com.digidesign.framework.DAE 0x0c20b99e FicGetContiguousMemRequirements + 14046 9 com.digidesign.framework.DAE 0x0c1bf4a5 FicMain + 69 10 com.digidesign.framework.DAE 0x0c1be860 InitFic + 160 11 com.digidesign.framework.ProTools 0x09d49d26 MFortressHWBPEntryPoint_exit_mfort6317_ + 9006972 12 com.digidesign.framework.ProTools 0x09d4af22 MFortressHWBPEntryPoint_exit_mfort6317_ + 9011576 13 com.digidesign.framework.ProTools 0x0acb6a8b MFortressHWBPEntryPoint_exit_mfort6317_ + 25181409 14 com.digidesign.framework.DFW 0x0059a78b TCommandHandler::PerformCommand(TCommand*) + 187 15 com.digidesign.framework.DFW 0x0059b0df TCommand::Process() + 31 16 com.digidesign.framework.DFW 0x00590b8a TApplication::ProcessEvent(TEvent*) + 26 17 com.digidesign.framework.DFW 0x005914a0 TApplication::WakeUp() + 64 18 com.digidesign.framework.DFW 0x006f751b TApplication::CreateNewOSApplication(void*, void*, void*) + 667 19 com.apple.HIToolbox 0x943cbc0c _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36 20 com.apple.HIToolbox 0x94247313 _ZL23DispatchEventToHandlersP14EventTargetRecP14Op aqueEventRefP14HandlerCallRec + 1602 21 com.apple.HIToolbox 0x94246790 _ZL30SendEventToEventTargetInternalP14OpaqueEventR efP20OpaqueEventTargetRefP14HandlerCallRec + 482 22 com.apple.HIToolbox 0x942465a8 SendEventToEventTargetWithOptions + 75 23 com.apple.HIToolbox 0x9425c1c6 _ZL29ToolboxEventDispatcherHandlerP25OpaqueEventHa ndlerCallRefP14OpaqueEventRefPv + 3152 24 com.apple.HIToolbox 0x942477ce _ZL23DispatchEventToHandlersP14EventTargetRecP14Op aqueEventRefP14HandlerCallRec + 2813 25 com.apple.HIToolbox 0x94246790 _ZL30SendEventToEventTargetInternalP14OpaqueEventR efP20OpaqueEventTargetRefP14HandlerCallRec + 482 26 com.apple.HIToolbox 0x9425b571 SendEventToEventTarget + 76 27 com.apple.HIToolbox 0x943cba58 ToolboxEventDispatcher + 82 28 com.apple.HIToolbox 0x943cbb87 RunApplicationEventLoop + 236 29 com.digidesign.framework.DFW 0x00700a5b DFW_EventLoop::RunApplicationEventLoop() + 11 30 com.digidesign.framework.DFW 0x00590c5d TApplication::Run() + 45 31 com.digidesign.framework.ProTools 0x0aefc1b1 MFortressHWBPEntryPoint_exit_mfort6317_ + 27563015 32 com.digidesign.framework.ProTools 0x0aefd6d4 LaunchProTools + 1412 33 com.digidesign.ProTools 0x0000f277 0x1000 + 57975 34 com.digidesign.ProTools 0x0001037a 0x1000 + 62330 35 com.digidesign.ProTools 0x0000effd 0x1000 + 57341 Thread 1:: Dispatch queue: com.apple.libdispatch-manager 0 libsystem_kernel.dylib 0x9555c90a kevent + 10 1 libdispatch.dylib 0x9a0f7e04 _dispatch_mgr_invoke + 969 2 libdispatch.dylib 0x9a0f6853 _dispatch_mgr_thread + 53 Thread 2: 0 libsystem_kernel.dylib 0x9555c02e __workq_kernreturn + 10 1 libsystem_c.dylib 0x93581ccf _pthread_wqthread + 773 2 libsystem_c.dylib 0x935836fe start_wqthread + 30 Thread 3: 0 libsystem_kernel.dylib 0x9555c02e __workq_kernreturn + 10 1 libsystem_c.dylib 0x93581ccf _pthread_wqthread + 773 2 libsystem_c.dylib 0x935836fe start_wqthread + 30 Thread 4: 0 libsystem_kernel.dylib 0x95559c5e semaphore_wait_trap + 10 1 com.digidesign.framework.digitrace 0x0151398a digitrace_initialize + 10122 2 com.digidesign.framework.digitrace 0x015180df DigiTraceIsActiveFunc + 1263 3 com.digidesign.framework.digitrace 0x01518265 DigiTraceIsActiveFunc + 1653 4 com.digidesign.framework.digitrace 0x015183c1 DigiTraceIsActiveFunc + 2001 5 libsystem_c.dylib 0x9357fed9 _pthread_start + 335 6 libsystem_c.dylib 0x935836de thread_start + 34 Thread 5: 0 libsystem_kernel.dylib 0x95559c22 mach_msg_trap + 10 1 libsystem_kernel.dylib 0x955591f6 mach_msg + 70 2 com.apple.CoreFoundation 0x946159da __CFRunLoopServiceMachPort + 170 3 com.apple.CoreFoundation 0x9461eb04 __CFRunLoopRun + 1428 4 com.apple.CoreFoundation 0x9461e1dc CFRunLoopRunSpecific + 332 5 com.apple.CoreFoundation 0x9462ef01 CFRunLoopRun + 129 6 com.digidesign.framework.ProTools 0x0aef9a97 MFortressHWBPEntryPoint_exit_mfort6317_ + 27553005 7 libsystem_c.dylib 0x9357fed9 _pthread_start + 335 8 libsystem_c.dylib 0x935836de thread_start + 34 Thread 6: 0 libsystem_kernel.dylib 0x95559c22 mach_msg_trap + 10 1 libsystem_kernel.dylib 0x955591f6 mach_msg + 70 2 com.digidesign.framework.CoreFoundation 0x0024f372 Sys_MachExceptionHandler::Init(bool, int) + 706 3 libsystem_c.dylib 0x9357fed9 _pthread_start + 335 4 libsystem_c.dylib 0x935836de thread_start + 34 Thread 7: 0 libsystem_kernel.dylib 0x95559c22 mach_msg_trap + 10 1 libsystem_kernel.dylib 0x955591f6 mach_msg + 70 2 com.apple.CoreFoundation 0x946159da __CFRunLoopServiceMachPort + 170 3 com.apple.CoreFoundation 0x9461eb04 __CFRunLoopRun + 1428 4 com.apple.CoreFoundation 0x9461e1dc CFRunLoopRunSpecific + 332 5 com.apple.CoreFoundation 0x9462ef01 CFRunLoopRun + 129 6 com.digidesign.framework.DAE 0x0c1beda7 FicIsAlive + 983 7 libsystem_c.dylib 0x9357fed9 _pthread_start + 335 8 libsystem_c.dylib 0x935836de thread_start + 34 Thread 8: 0 libsystem_kernel.dylib 0x9555b2de __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c6e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008d152e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.CoreFoundation 0x00249846 Sys_BlockingTimer:estroy(Sys_BlockingTimer*&) + 886 4 com.digidesign.framework.CoreFoundation 0x0022d280 Sys_RawThreadTimerTask::Exec() + 64 5 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 6 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 7 com.digidesign.framework.PlatformSupport 0x008c72a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 8 libsystem_c.dylib 0x9357fed9 _pthread_start + 335 9 libsystem_c.dylib 0x935836de thread_start + 34 Thread 9: 0 libsystem_kernel.dylib 0x9555b2de __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c6e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008d152e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.CoreFoundation 0x00249846 Sys_BlockingTimer:estroy(Sys_BlockingTimer*&) + 886 4 com.digidesign.framework.CoreFoundation 0x0022d280 Sys_RawThreadTimerTask::Exec() + 64 5 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 6 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 7 com.digidesign.framework.PlatformSupport 0x008c72a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 8 libsystem_c.dylib 0x9357fed9 _pthread_start + 335 9 libsystem_c.dylib 0x935836de thread_start + 34 Thread 10: 0 libsystem_kernel.dylib 0x9555b2de __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c6e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008d152e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.DAE 0x0c22ce00 FicGetContiguousMemRequirements + 150336 4 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 5 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 6 com.digidesign.framework.PlatformSupport 0x008c72a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 7 libsystem_c.dylib 0x9357fed9 _pthread_start + 335 8 libsystem_c.dylib 0x935836de thread_start + 34 Thread 11: 0 libsystem_kernel.dylib 0x95559d36 mach_wait_until + 10 1 com.apple.CoreServices.CarbonCore 0x9ac117f8 MPDelayUntil + 29 2 com.apple.CoreServices.CarbonCore 0x9ac23694 Delay + 108 3 se.propellerheads.rewire.library 0x0f19d7e8 RWPUnregisterDeviceImp + 21574 4 se.propellerheads.rewire.library 0x0f1b8a5c RWPUnregisterDeviceImp + 132794 5 libsystem_c.dylib 0x9357fed9 _pthread_start + 335 6 libsystem_c.dylib 0x935836de |
#16
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x0c4bf8cc ebx: 0x0c1cb13e ecx: 0x0c4d2080 edx: 0xacaefe48 edi: 0x00000000 esi: 0x945ea91d ebp: 0xbfffdbf8 esp: 0xbfffdbe0 ss: 0x00000023 efl: 0x00010282 eip: 0x945ea921 cs: 0x0000001b ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f cr2: 0x00000000 Logical CPU: 2 Binary Images: 0x1000 - 0x142fef +com.digidesign.ProTools (10.3.8.378 - 10.3.8f378) <16C86F4E-9345-4B33-AF0E-AEE96102643E> /Applications/Avid/*/Pro Tools.app/Contents/MacOS/Pro Tools 0x173000 - 0x174fff +com.avid.breakpad_glue (??? - 1.0) <4DBF4DE3-C441-48E5-E6E6-F7013117A3B2> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/breakpad_glue.framework/Versions/A/breakpad_glue 0x178000 - 0x42afef +com.digidesign.framework.CoreFoundation (10.3.8.378 - 10.3.8f378) <5CCC8F96-3FE7-6B9A-1324-90AC8BAD000E> /Library/Frameworks/CFnd.framework/Versions/A/CFnd 0x4cb000 - 0x517ffb com.apple.audio.midi.CoreMIDI (1.8 - 42) <292E006C-CB38-39AD-9AAD-0151D9AF060D> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI 0x53a000 - 0x7e5fff +com.digidesign.framework.DFW (10.3.8.378 - 10.3.8f378) <24393C7C-DE98-A20C-48D7-B1419F0B296B> /Library/Frameworks/DFW.framework/Versions/A/DFW 0x8bf000 - 0x8edffb +com.digidesign.framework.PlatformSupport (10.3.8.378 - 10.3.8f378) <5C7B54BE-2FFB-8E22-7037-78F91F6A76F6> /Library/Frameworks/DigiPlatformSupport.framework/Versions/A/DigiPlatformSupport 0x90e000 - 0x9c0fff +com.digidesign.framework.DSI (10.3.8.378 - 10.3.8f378) <1C3586E8-0717-1920-DFB1-C4831A7CFD3E> /Library/Frameworks/DSI.framework/Versions/A/DSI 0x9f6000 - 0xe50fe7 +com.digidesign.framework.FileFormat (10.3.8.378 - 10.3.8f378) <4AD88602-C346-F7CF-1733-743C8D0516AA> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/FFmt.framework/Versions/A/FFmt 0xf11000 - 0xf19ff7 +com.googlecode.google-breakpad (??? - 1.0) <B7F25F49-C2CA-0D4C-1E15-1F76C3DA5DBA> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/Breakpad.framework/Versions/A/Breakpad 0xf21000 - 0xf31fe7 +breakpadUtilities.dylib (??? - ???) <727F0977-5BE6-FF34-9156-AE801022D2E4> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/Breakpad.framework/Versions/A/Resources/breakpadUtilities.dylib 0xf3d000 - 0x1263fff +libNeoAccessPro.dylib (10.3.8 - compatibility 10.3.8) <8119DFB0-4625-04E9-F9E8-D64279E5EA99> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/libNeoAccessPro.dylib 0x12c2000 - 0x12c5ff7 +com.digidesign.framework.LGC (10.3.8x378 - 10.3.8d378) <9DF70D69-2F93-4EC2-659B-8A5157500D98> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/LGC.framework/Versions/A/LGC 0x12ca000 - 0x1395fe3 +libOMFToolkit.dylib (10.3.8 - compatibility 10.3.8) <7090C9C2-83BF-20D3-A5A3-AD3EC745B9AE> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/libOMFToolkit.dylib 0x13af000 - 0x13c5ff7 +com.digidesign.framework.AudioFoundation (10.3.8.378 - 10.3.8f378) <0FA885AE-09AD-45F7-906D-5C131EBC807F> /Library/Frameworks/AFnd.framework/Versions/A/AFnd 0x150d000 - 0x151cffb +com.digidesign.framework.digitrace (10.3.8.378 - 10.3.8f378) <D05F092E-09B4-5A44-1908-1A0D79738277> /Library/Application Support/Avid/*/Digitrace.framework/Digitrace 0x2fd0000 - 0x2feeff3 +com.digidesign.framework.CFD (10.3.8.378 - 10.3.8f378) <CE8404BC-313C-B592-5DB9-AD3D5533FD4B> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/CFD.framework/Versions/A/CFD 0x2ff6000 - 0x2ffbfff +com.digidesign.framework.AAXShared (10.3.8.378 - 10.3.8f378) <C5231616-23DF-5AF3-BAEA-AFFEC04E6591> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/AAXShared.framework/Versions/A/AAXShared 0x4b29000 - 0x4b34ff3 +com.digidesign.framework.TableView (1.0 - 10.3.8f378) <672A9098-DF84-5C3F-FAA8-39ED4DA5A20B> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/TableView.framework/Versions/A/TableView 0x4b43000 - 0x4b46ff3 +libFicClockComponent.dylib (10.3.8 - compatibility 10.3.8) <D38363A3-FAFD-8997-78A4-F1494A3D7161> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/libFicClockComponent.dylib 0x7fb1000 - 0x7fcbffb +com.digidesign.framework.DMC (10.3.8.378 - 10.3.8f378) <7307F987-B426-AA0C-E397-D34739825768> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/DMC.framework/Versions/A/DMC 0x7fda000 - 0x7fe4ffb +VenueLink (10.3.8 - compatibility 10.3.8) <B0368280-1459-53F3-19D2-916E99CFF941> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/VenueLink.framework/Versions/A/VenueLink 0x7ff5000 - 0x7ff9ff7 +com.digidesign.framework.TISys (10.3.8.378 - 10.3.8f378) <25F19F76-C686-04C5-A3D2-17642B089ADD> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/TISys.framework/Versions/A/TISys 0x91ee000 - 0x91f7ff7 +com.digidesign.framework.KMM (10.3.8.378 - 10.3.8f378) <F128F5B8-FC08-CC91-02F6-427860D7DC4A> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/KMM.framework/Versions/A/KMM 0x9400000 - 0xbbc8fe3 +com.digidesign.framework.ProTools (10.3.8.378 - 10.3.8f378) <883775DA-CBC5-CD80-920F-C56BB1BFE811> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/Pro Tools.framework/Pro Tools 0xc1b2000 - 0xc4a0fe3 +com.digidesign.framework.DAE (10.3.8.378 - 10.3.8f378) <0A6895C8-76E7-647D-B434-6814C6E728B1> /Library/Frameworks/DAE.framework/Versions/A/DAE 0xc4ff000 - 0xc66cff3 +com.digidesign.framework.SystemLink (10.3.8.378 - 10.3.8f378) <E69DFC03-993F-45F1-63B2-62C58A329515> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/SystemLink.framework/Versions/A/SystemLink 0xc6ba000 - 0xc6feffb +com.digidesign.framework.Sib (1.0 - 1.0) <05E47C32-90F2-DE03-E17D-F374EF0D9D43> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/Sib.framework/Versions/A/Sib 0xc729000 - 0xc800ffb +com.digidesign.framework.BUI (10.3.8.378 - 10.3.8f378) <518C8920-8D15-8F0B-02A8-7F1CCE185032> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/BUI.framework/Versions/A/BUI 0xc84d000 - 0xc8b4ff3 +com.digidesign.framework.Gtr (10.3.8.378 - 10.3.8f378) <44AC2A0A-C0ED-CAFA-05EC-2DC3AA9A71A8> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/Gtr.framework/Versions/A/Gtr 0xc8d2000 - 0xc8ecfef +com.digidesign.framework.TCPE (10.3.8.378 - 10.3.8f378) <C1E4CEBF-8029-515F-8CFA-0EEFBB6F4565> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/TCPE.framework/Versions/A/TCPE 0xc8fc000 - 0xcaacffb +com.avid.framework.TIShellMgr (10.3.8.378 - 10.3.8f378) <35F0EA51-94EF-9F03-5776-48F13A13798F> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/TIShellMgr.framework/Versions/A/TIShellMgr 0xcb2a000 - 0xcb51ff7 +com.digidesign.framework.TIDSPMgr (10.3.8.378 - 10.3.8f378) <13451BEB-5A2F-3D92-B82B-BF6B06EFD8FF> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/TIDspMgr.framework/Versions/A/TIDspMgr 0xcb58000 - 0xcd45ffb +com.avid.framework.AAXHost (10.3.8.378 - 10.3.8f378) <1F27D4BE-9456-431E-FE9E-BCFB3EEAD9E4> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/AAXHost.framework/Versions/A/AAXHost 0xcd8f000 - 0xcdceffb +com.digidesign.framework.DSPManager (10.3.8.378 - 10.3.8f378) <9116E0A3-461B-2111-607E-1986A55AC658> /Library/Frameworks/DSPManager.framework/Versions/A/DSPManager 0xcdd6000 - 0xce18fe7 +com.digidesign.framework.DSK (10.3.8.378 - 10.3.8f378) <AFAFA1F2-D8EB-37F6-392D-BFA0760E7215> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/DSK.framework/Versions/A/DSK 0xce23000 - 0xce52fff +com.digidesign.framework.CDS (10.3.8.378 - 10.3.8f378) <3AD487E0-34AA-B81B-93E3-C5A0F30BB073> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/CDS.framework/Versions/A/CDS 0xce59000 - 0xce6dff7 +libTrns.dylib (10.3.8 - compatibility 10.3.8) <878DDDEF-8B57-03BE-3A78-2D1CC61D1658> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/libTrns.dylib 0xe287000 - 0xe29ffff com.apple.OpenTransport (10.6.0 - 10.6.0) <096C28DD-DAB9-335C-886E-0A6DF10F2144> /System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport 0xe2b0000 - 0xe2b4ffb com.apple.audio.AudioIPCPlugIn (1.2.3 - 1.2.3) <D4092467-5BBE-3ED6-A493-7DB1EE8E6686> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn 0xe2b9000 - 0xe2befff com.apple.audio.AppleHDAHALPlugIn (2.2.5 - 2.2.5a5) <BAD1E0E6-10E6-342C-BEB8-B1706F0CE2CF> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn 0xe2c3000 - 0xe2f0fe3 +com.avid.avid.AvidCoreAudioPlugIn (10.3.8.378 - 10.3.8f378) <3F0E16DB-C547-491B-9CBE-1E7B330C4054> /Library/Audio/Plug-Ins/HAL/Avid CoreAudio.plugin/Contents/MacOS/Avid CoreAudio 0xf100000 - 0xf16bffb +com.digidesign.plugin.DigiReWire (10.3.8.378 - 10.3.8f378) <FDABD157-87CC-7ABB-9760-C922F2897E89> /Library/Application Support/Digidesign/*/DigiReWire 0xf192000 - 0xf1f1fe1 +se.propellerheads.rewire.library (1.7 - 1.7) /Users/USER/Library/Application Support/Propellerhead Software/*/ReWire.bundle/Contents/MacOS/ReWire 0xf210000 - 0xf285feb +com.digidesign.plugin.SignalGenerator (8.0.0 - 8.0.0f314) <A1D4E580-71BE-08CF-EC16-51112EE3D4B4> /Library/Application Support/Digidesign/*/Signal Generator 0xf2dd000 - 0xf362fe3 +com.digidesign.mixer.surround (10.3.8.378 - 10.3.8f378) <BA4C7967-DEEC-460D-FF8F-1A035CFE952F> /Library/Application Support/Digidesign/*/Surround Mixer 0x8feef000 - 0x8ff21aa7 dyld (195.6 - ???) <3A866A34-4CDD-35A4-B26E-F145B05F3644> /usr/lib/dyld 0x90008000 - 0x90015fff libGL.dylib (??? - ???) <A72F14F7-1836-34AB-9F08-67836CB966E4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x90016000 - 0x90026ff7 libCRFSuite.dylib (??? - ???) <B68CDEA4-8D6E-3625-B80F-3489E321E858> /usr/lib/libCRFSuite.dylib 0x90033000 - 0x90041fff com.apple.opengl (1.8.1 - 1.8.1) <766AFB12-A2CB-3A55-B662-FC9FFCAE0008> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x90042000 - 0x90094ffb com.apple.CoreMediaIO (216.0 - 3199.8) <A079E576-64FD-3069-846E-F3B67AF28E15> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO 0x900b7000 - 0x901e3ff9 com.apple.CFNetwork (520.5.1 - 520.5.1) <F3C606BF-6DCF-33CD-981B-7253C9E3113A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x901e4000 - 0x901ebff9 libsystem_dnssd.dylib (??? - ???) <EBEAF723-84F8-3544-8FB2-31B7771B50D0> /usr/lib/system/libsystem_dnssd.dylib 0x901ec000 - 0x9024effb com.apple.datadetectorscore (3.0 - 179.4) <6CB6E69A-314D-329E-B0E7-DFB02531575D> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore 0x9024f000 - 0x902caffb com.apple.ApplicationServices.ATS (317.12.0 - ???) <4D124B65-3D43-32E9-B296-3671347BB888> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x902cb000 - 0x902dcfff libbsm.0.dylib (??? - ???) <BB4E736B-E068-376A-B28D-6B2D6A70EE50> /usr/lib/libbsm.0.dylib 0x902dd000 - 0x903cdff1 libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib 0x903ce000 - 0x903f0ff8 com.apple.PerformanceAnalysis (1.11 - 11) <0DDAD62E-381E-3FB6-A066-635870DCCCE5> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis 0x903f1000 - 0x903f4ffd libCoreVMClient.dylib (??? - ???) <B8F8916D-F12A-3D95-ABF3-999D57B7D581> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib 0x9040c000 - 0x90414ff3 liblaunch.dylib (392.39.0 - compatibility 1.0.0) <9E6135FF-C2B1-3BC9-A160-B32D71BFA77C> /usr/lib/system/liblaunch.dylib 0x9043f000 - 0x90443ffa libcache.dylib (47.0.0 - compatibility 1.0.0) <9DFB61F2-9B1F-31B2-BF41-099994D74E1F> /usr/lib/system/libcache.dylib 0x90444000 - 0x905a7fff com.apple.QTKit (7.7.1 - 2348) <E3312B31-238A-3021-9D23-9F2FD5F0B57A> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit 0x905a8000 - 0x905b3ffe com.apple.NetAuth (3.2 - 3.2) <FF3965FE-D897-3885-B5B9-33665D2F5318> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth 0x905b4000 - 0x905bcff3 libunwind.dylib (30.0.0 - compatibility 1.0.0) <E8DA8CEC-12D6-3C8D-B2E2-5D567C8F3CB5> /usr/lib/system/libunwind.dylib 0x905bd000 - 0x90644fff com.apple.print.framework.PrintCore (7.1 - 366.3) <EBD5A94E-8E1D-3510-9457-EB0EAE2F51EF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x906b4000 - 0x906b4ff2 com.apple.CoreServices (53 - 53) <F28F38DC-C5C1-399F-84D7-A28CCC269850> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x90c6c000 - 0x912f8ff5 com.apple.CoreAUC (6.16.12 - 6.16.12) <9D51400F-B827-3BA7-87F5-954A1CDDAEA9> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC 0x91671000 - 0x919b7fff com.apple.MediaToolbox (1.0 - 705.94) <89D37021-C389-3CC5-A158-620ADCBD99EF> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox 0x919b8000 - 0x919b9ff4 libremovefile.dylib (21.1.0 - compatibility 1.0.0) <DA59E228-076B-39B5-B6EA-52E6FD4EDC53> /usr/lib/system/libremovefile.dylib 0x919ba000 - 0x919f7fef libGLImage.dylib (??? - ???) <FC13D46F-69C4-3BA1-A5E8-52C2EC8B7D58> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x919f8000 - 0x91b08fe7 libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <34E1E3CC-7B6A-3B37-8D07-1258D11E16CB> /usr/lib/libsqlite3.dylib |
#17
0x91b09000 - 0x91b37ff7 com.apple.DictionaryServices (1.2.1 - 158.3) <8D03D180-D834-39F3-A106-78E0B22A7893> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x91b38000 - 0x91b8bff3 com.apple.ImageCaptureCore (3.1.0 - 3.1.0) <F7ACE42B-2F58-3642-9469-9CDCF31F0273> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore 0x91bc5000 - 0x91c14ffb com.apple.AppleVAFramework (5.0.16 - 5.0.16) <1188E7AB-76FE-343F-9108-30CD67E5A37B> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA 0x91c15000 - 0x91c2ffff com.apple.Kerberos (1.0 - 1) <A1ED8518-29DB-3511-83AE-EEAB2C0AB1FD> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x91c30000 - 0x91de4ff3 libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <4AFF6FC3-6283-3934-8EFC-CA227CA11164> /usr/lib/libicucore.A.dylib 0x91de5000 - 0x91ebbaab libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <C784297D-1FF6-3D89-9DE6-98C028AF73D2> /usr/lib/libobjc.A.dylib 0x91ebc000 - 0x91ed4ff7 libexpat.1.dylib (7.2.0 - compatibility 7.0.0) <C7003CC0-28CA-3E04-9B9E-0A15138ED726> /usr/lib/libexpat.1.dylib 0x91ed5000 - 0x9234aff7 FaceCoreLight (1.4.7 - compatibility 1.0.0) <3E2BF587-5168-3FC5-9D8D-183A9C7C1DED> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight 0x9234b000 - 0x92354ff3 com.apple.CommonAuth (2.2 - 2.0) <6F207851-084B-3354-A1B2-63065BC584F6> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth 0x92355000 - 0x92356ff0 libunc.dylib (24.0.0 - compatibility 1.0.0) <9EF47F4C-32F6-3379-A3DD-89183D821B48> /usr/lib/system/libunc.dylib 0x92357000 - 0x92373ff5 com.apple.GenerationalStorage (1.0 - 126.1) <E622F823-7D98-3D13-9C3D-7EA482567394> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage 0x92374000 - 0x92e09ff6 com.apple.AppKit (6.7.5 - 1138.51) <B9D3DCA0-9765-354E-9730-75A45A97DDFD> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x92e64000 - 0x92e7affe libxpc.dylib (77.19.0 - compatibility 1.0.0) <0585AA94-F4FD-32C1-B586-22E7184B781A> /usr/lib/system/libxpc.dylib 0x92e8f000 - 0x92eb7ff7 libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <AB530FB2-8BD1-3328-95E8-CF449F0429CA> /usr/lib/libxslt.1.dylib 0x92eb8000 - 0x92f9bff7 libcrypto.0.9.8.dylib (49.1.0 - compatibility 0.9.8) <819B5833-97F6-3827-8CAE-2F7CA91F0A0D> /usr/lib/libcrypto.0.9.8.dylib 0x92f9c000 - 0x93074ff6 com.apple.QuickLookUIFramework (3.2 - 500.18) <CE281BD9-C1CF-3F87-BD22-412ED253580E> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI 0x93075000 - 0x93080ffe libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <B63F5D07-93B3-3F02-BFB7-472B4ED3521F> /usr/lib/libbz2.1.0.dylib 0x9308d000 - 0x93091ff7 com.apple.OpenDirectory (10.7 - 146) <9C1EAEB1-84E0-373D-94E9-0E990752011E> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory 0x93092000 - 0x9333ffff com.apple.JavaScriptCore (7534.57 - 7534.57.3) <5AE5C3B8-D807-356B-80D9-4D0A706A10D1> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore 0x93346000 - 0x933d3fe7 libvMisc.dylib (325.4.0 - compatibility 1.0.0) <514C9266-865D-3655-BA59-A8BA4EA80EA1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x934b6000 - 0x934e0ff1 com.apple.CoreServicesInternal (113.19 - 113.19) <F7A309D1-DCB4-38DE-8248-E16D0182AA6C> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal 0x934e1000 - 0x934e2ff7 libsystem_sandbox.dylib (??? - ???) <036370E2-9D3E-38B8-B3A5-9056C57E780E> /usr/lib/system/libsystem_sandbox.dylib 0x93523000 - 0x935eefff libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <03E608FA-1689-3D85-9A21-31C1922AEC1A> /usr/lib/system/libsystem_c.dylib 0x935ef000 - 0x93606ff8 com.apple.CoreMediaAuthoring (2.0 - 891) <69D569FD-670C-3BD0-94BF-7A8954AA2953> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring 0x93607000 - 0x93ae3ff6 libBLAS.dylib (??? - ???) <67AF68CD-8E05-3355-92D1-341C2A9A6BCF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x93ae4000 - 0x93ae4fff libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <7EFAD88C-AFBC-3D48-BE14-60B8EACC68D7> /usr/lib/system/libdnsinfo.dylib 0x93ae5000 - 0x93b0bffb com.apple.quartzfilters (1.7.0 - 1.7.0) <7C576167-4A7E-37A3-9B27-52A79CF14BB7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters 0x93b0c000 - 0x93c1dff7 libJP2.dylib (??? - ???) <3B6A6D1C-5E4D-3814-892A-7C580E063268> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib 0x93c1e000 - 0x93e92ff3 com.apple.CoreImage (7.99.1 - 1.0.1) <C4B2DD2A-8E45-31CD-9B25-2AC1CA252B14> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage 0x93e93000 - 0x93ff5ffb com.apple.QuartzCore (1.7 - 270.5) <6D0EC7FC-11E5-35FB-A08A-3B438E89FBDB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x93ff6000 - 0x93ffeff5 libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <97E73059-F645-33F4-BCC5-1FEA367D60D4> /usr/lib/system/libcopyfile.dylib 0x94227000 - 0x94229ffb libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x9422a000 - 0x9423efff com.apple.CFOpenDirectory (10.7 - 146) <A7A0D36A-B14A-36C7-BFE5-E21130BF3687> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory 0x9423f000 - 0x94585ff3 com.apple.HIToolbox (1.9 - ???) <E5EA9EEF-3CCA-36A0-8688-DA2E64E2256C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x945e3000 - 0x947bafe7 com.apple.CoreFoundation (6.7.2 - 635.21) <4D1D2BAF-1332-32DF-A81B-7E79D4F0A6CB> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x947c1000 - 0x94891ffb com.apple.ImageIO.framework (3.1.2 - 3.1.2) <C3CB142F-BE91-3AFA-B052-409F776C0B9E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x94892000 - 0x948b5fff com.apple.CoreVideo (1.7 - 70.3) <3CAFA7B1-0A0F-3F4E-9A9B-BEDDEEF64F6C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x948b6000 - 0x948b6fff com.apple.Carbon (153 - 153) <63603A0C-723B-3968-B302-EBEEE6A14E97> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x948b7000 - 0x9491bfff com.apple.framework.IOKit (2.0 - ???) <94827954-5906-36C4-819B-24CDAFD85C72> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x951eb000 - 0x951f3fff com.apple.DiskArbitration (2.4.1 - 2.4.1) <751DC709-220B-3FA3-9D67-CB1CC5E6861C> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x951f4000 - 0x9522bfef com.apple.DebugSymbols (2.1 - 87) <EB951B78-31A5-379F-AFA1-B5C9A7BB3D23> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols 0x9522c000 - 0x9526afff libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <AF1174F9-4402-31EB-9C84-AB644E5865DF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib 0x952b5000 - 0x952b9ffd IOSurface (??? - ???) <77B632E4-2196-3BC9-93CC-70EBF353CD4F> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface 0x952cb000 - 0x95328ffb com.apple.htmlrendering (76 - 1.1.4) <792F1D51-3A88-3430-8A32-F252FAAE0D13> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering 0x95329000 - 0x95400ff3 com.apple.avfoundation (2.0 - 180.50) <7B7FDF30-AC40-3715-A409-B5A27F7B5585> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation 0x95401000 - 0x95510ff7 com.apple.DesktopServices (1.6.5 - 1.6.5) <CEC069D7-37A3-3D25-A3BB-39DE99FDA46E> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x95538000 - 0x95542ff2 com.apple.audio.SoundManager (3.9.4.1 - 3.9.4.1) <79D55070-BBFF-3D67-AFB9-3668FF8C5F98> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound 0x95543000 - 0x95561ff7 libsystem_kernel.dylib (1699.32.7 - compatibility 1.0.0) <79179F83-457A-3539-A76B-E960D2108109> /usr/lib/system/libsystem_kernel.dylib 0x95562000 - 0x956b8fff com.apple.audio.toolbox.AudioToolbox (1.7.3 - 1.7.3) <F09C7075-2C4E-3A4F-A372-95D700125513> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x9579c000 - 0x957beffe com.apple.framework.familycontrols (3.0 - 300) <6735D7ED-7053-3AB8-B144-E7F70A124CCD> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls 0x96138000 - 0x9614bff8 com.apple.MultitouchSupport.framework (231.4 - 231.4) <BF359317-8ECA-34F7-8931-059C8735F343> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport 0x9616b000 - 0x961c9ff7 com.apple.coreui (1.2.2 - 165.11) <340B0B83-1407-3AB4-BCAB-505C29303EE2> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI 0x961ca000 - 0x96213ff7 libGLU.dylib (??? - ???) <9AF7AD51-16E3-3674-B60E-30EE499D7B46> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x96214000 - 0x964e3ffb com.apple.security (7.0 - 55148.6) <8DF67BDD-C98F-3B7E-AC63-D468407FA82D> /System/Library/Frameworks/Security.framework/Versions/A/Security 0x966e6000 - 0x966e9ff7 libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib 0x966ea000 - 0x966edffb com.apple.help (1.3.2 - 42) <46BC94D1-14C4-3178-9BFB-85470F1ED805> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x96725000 - 0x9676cff5 com.apple.opencl (2.0.19 - 2.0.19) <7689E7B9-EE5A-3F74-8699-4CDED9162260> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL 0x9676d000 - 0x96770ffc libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib |
#18
0x96771000 - 0x96774ff7 libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
0x96775000 - 0x96991ff7 com.apple.imageKit (2.1.2 - 1.0) <71FC9A62-4E07-307C-8E6B-4DE7661DC0A3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit 0x96992000 - 0x969d2ff7 libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib 0x969de000 - 0x969defff libOpenScriptingUtil.dylib (??? - ???) <E4C22B65-9493-31D5-9D46-19BD70975587> /usr/lib/libOpenScriptingUtil.dylib 0x96a35000 - 0x96a87ff7 libFontRegistry.dylib (??? - ???) <C2B84661-A62D-3FFF-8D8C-BC697E9BDF4C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib 0x96a88000 - 0x96aa4ff1 libPng.dylib (??? - ???) <F084226B-14F0-36C0-B5EC-22C78406D2B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x96aa5000 - 0x96b06ffb com.apple.audio.CoreAudio (4.0.3 - 4.0.3) <7A14BE52-6789-3CE3-9AE9-B733F4903EB1> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x96b07000 - 0x96b27ff7 com.apple.RemoteViewServices (1.5 - 44.2) <11C87337-FF29-3976-A230-6387D96563C5> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices 0x96b28000 - 0x96dadfe3 com.apple.QuickTime (7.7.1 - 2348) <DAA61DE5-ED45-3AAE-8030-351D2C636FF2> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime 0x96dae000 - 0x96e71fff com.apple.CoreServices.OSServices (478.50 - 478.50) <916A3B50-1033-3FFE-A9AF-3CC2B0F60EAE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x96e72000 - 0x96e78fff libGFXShared.dylib (??? - ???) <9C9834EB-B794-38C8-9B90-31D8CB234F86> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib 0x96eb7000 - 0x96ec5ff7 libxar-nossl.dylib (??? - ???) <9C927E1E-D9F6-34AE-979F-5D60E7E9211C> /usr/lib/libxar-nossl.dylib 0x96f07000 - 0x96f1cff7 com.apple.ImageCapture (7.1.0 - 7.1.0) <E5FCA336-7E47-343E-A82D-CCCA5BCD5929> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x96f36000 - 0x97240ff3 com.apple.Foundation (6.7.2 - 833.25) <361418ED-589D-36DE-9668-A88B35937524> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x97241000 - 0x97247ffb com.apple.print.framework.Print (7.4 - 247.3) <CB075EEE-FA1F-345C-A1B5-1AB266FC73A1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x972e9000 - 0x972f9fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <8BE2D2EF-9AF0-3960-9845-052CCE04B53A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x97457000 - 0x974e4ff7 com.apple.CoreText (220.22.0 - ???) <EA7210A7-DECC-3F76-8A66-D4E41859B3C6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText 0x97562000 - 0x975d1fff com.apple.Heimdal (2.2 - 2.0) <8ACC5067-441D-31C2-ACBD-4527C1AD73EF> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal 0x975d2000 - 0x975d2fff com.apple.audio.units.AudioUnit (1.7.3 - 1.7.3) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x975d7000 - 0x977cfff7 com.apple.CoreData (104.1 - 358.14) <92830C09-780F-3021-ADC0-2D9BB56D8E7B> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x977da000 - 0x9820bfff com.apple.WebCore (7534.57 - 7534.57.7) <5FF60D46-9BC0-3B5A-AFF1-2C965D561009> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore 0x9820c000 - 0x9824fffd libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <4BA1F5F1-F0A2-3FEB-BB62-F514DCBB3725> /usr/lib/system/libcommonCrypto.dylib 0x98250000 - 0x98254ff3 libsystem_network.dylib (??? - ???) <6C0CB421-5DDD-3BD4-B3C5-C1DB6037576F> /usr/lib/system/libsystem_network.dylib 0x98255000 - 0x98297ff7 com.apple.CoreMedia (1.0 - 705.94) <10D5D25F-9BCB-3406-B737-23D9FDF2CC71> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia 0x98333000 - 0x9842bff7 libFontParser.dylib (??? - ???) <71B33EB1-27F8-3C68-B940-FC61A3CFE275> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib 0x9843c000 - 0x987f7ffb com.apple.SceneKit (125.3 - 125.8) <89008B87-87E7-3972-A274-30311497EE32> /System/Library/PrivateFrameworks/SceneKit.framework/Versions/A/SceneKit 0x987f8000 - 0x987f9ffd libCVMSPluginSupport.dylib (??? - ???) <4B0476F9-950D-3EB7-BD83-F65AF0B05F0E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib 0x987fa000 - 0x987fbfff libDiagnosticMessagesClient.dylib (??? - ???) <DB3889C2-2FC2-3087-A2A2-4C319455E35C> /usr/lib/libDiagnosticMessagesClient.dylib 0x987fc000 - 0x98872fff com.apple.Metadata (10.7.0 - 627.37) <F54AED70-95C5-3561-8C87-D9E5539E98A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x988cd000 - 0x989e4fe9 com.apple.WebKit (7534.57 - 7534.57.7) <85DAC34E-86A1-380F-B166-56630C9B0BD5> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit 0x989e5000 - 0x989ecfff com.apple.agl (3.2.0 - AGL-3.2.0) <210F3383-D8EA-3644-90BA-9F054E15A2AB> /System/Library/Frameworks/AGL.framework/Versions/A/AGL 0x98b5c000 - 0x98bd0fff com.apple.CoreSymbolication (2.2 - 73.2) <FA9305CA-FB9B-3646-8C41-FF8DF15AB2C1> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication 0x98bd1000 - 0x98bd1ff0 com.apple.ApplicationServices (41 - 41) <45032433-76F6-365A-95CA-641C9427EAA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x98bfb000 - 0x98c25ff0 libpcre.0.dylib (1.1.0 - compatibility 1.0.0) <5CAA1478-97E0-31EA-8F50-BF09D665DD84> /usr/lib/libpcre.0.dylib 0x98c26000 - 0x98c63ff7 libcups.2.dylib (2.9.0 - compatibility 2.0.0) <007A1877-E981-3007-A8FA-9B179F4ED6D1> /usr/lib/libcups.2.dylib 0x98c64000 - 0x98c67fff com.apple.AppleSystemInfo (1.0 - 1) <58A563D5-8C1B-323F-9C5A-3869DD9C2320> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo 0x98c68000 - 0x98c73ff3 libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <D6E17FD4-ECA0-3EEE-BFC5-F6A42A21AB5D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib 0x98c76000 - 0x98ccffff com.apple.HIServices (1.21 - ???) <91EC636D-AC27-3332-BA1C-FD7301917429> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x98cd1000 - 0x98ceeff3 com.apple.openscripting (1.3.3 - ???) <0579A4CB-FD6F-3D7F-A17B-AC0F2CF11FC7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x98cef000 - 0x98d51ff3 libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib 0x98d52000 - 0x98df6fff com.apple.QD (3.40.1 - ???) <B5650C5E-AB41-3758-84A1-5A97EDCD8EFE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x98df7000 - 0x98f15fec com.apple.vImage (5.1 - 5.1) <7757F253-B281-3612-89D4-F2B04061CBE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x98f16000 - 0x98f17fff liblangid.dylib (??? - ???) <C8C204E9-1785-3785-BBD7-22D59493B98B> /usr/lib/liblangid.dylib 0x98f18000 - 0x98f1cfff libGIF.dylib (??? - ???) <2ADFED97-2228-343D-9A53-207CBFDE7984> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x98f1d000 - 0x98f6eff9 com.apple.ScalableUserInterface (1.0 - 1) <3E650401-FB58-3704-8A24-E0B2F3914884> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface 0x98f6f000 - 0x98f78fff libc++abi.dylib (14.0.0 - compatibility 1.0.0) <FEB5330E-AD5D-37A0-8AB2-0820F311A2C8> /usr/lib/libc++abi.dylib 0x992ba000 - 0x99332ff8 com.apple.CorePDF (3.1 - 3.1) <0C7FE9C2-D743-3FA1-8CAB-48139F1A3B02> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF 0x9a0f5000 - 0x9a103fff libdispatch.dylib (187.10.0 - compatibility 1.0.0) <1B857064-288D-3919-B81A-38E9F4D19B54> /usr/lib/system/libdispatch.dylib 0x9a104000 - 0x9a13aff7 com.apple.AE (527.7 - 527.7) <DC987937-BA90-3588-8482-689EA5580BEE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x9a16f000 - 0x9a39affb com.apple.QuartzComposer (5.0 - 236.10) <416993F4-2868-35FF-90DE-34C93D83574F> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer 0x9a39b000 - 0x9a3ecff9 com.apple.QuickLookFramework (3.2 - 500.18) <CF3EF345-EA3E-3C2D-B56D-E4433326254A> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook 0x9a3ed000 - 0x9a3f4ffd com.apple.NetFS (4.0 - 4.0) <0F1B19AD-B320-38BE-8543-9DA93792F220> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS 0x9a53f000 - 0x9a5d5ff7 com.apple.LaunchServices (480.40 - 480.40) <D5C0DEF9-398C-3742-8C4E-875C3365EC8B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x9a5d6000 - 0x9a5dbff7 libmacho.dylib (800.0.0 - compatibility 1.0.0) <6DCCA207-8F4D-343A-B77D-C4FB905DADC4> /usr/lib/system/libmacho.dylib 0x9a75b000 - 0x9a769fff libz.1.dylib (1.2.5 - compatibility 1.0.0) <E73A4025-835C-3F73-9853-B08606E892DB> /usr/lib/libz.1.dylib 0x9a76a000 - 0x9a76bfff libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <B04592B1-0924-3422-82FF-976B339DF567> /usr/lib/system/libsystem_blocks.dylib 0x9a922000 - 0x9a947ff9 libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x9a948000 - 0x9a948fff com.apple.quartzframework (1.5 - 1.5) <E897CB0C-1CCC-393F-AE36-A182723AFD37> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz 0x9a949000 - 0x9a94fffd com.apple.CommerceCore (1.0 - 17.1) <32AB16CE-7BBB-3124-8C42-2EE3E1D336F0> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore 0x9a950000 - 0x9a959ffc com.apple.DisplayServicesFW (2.5.4 - 323.3) <942A05FB-D8C9-378D-B206-81EACB3D4808> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices 0x9a95a000 - 0x9a95efff com.apple.CommonPanels (1.2.5 - 94) <DFA0D001-9890-32FB-B1BD-039DDA8F3E9E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x9a95f000 - 0x9a98afff com.apple.GSS (2.2 - 2.0) <1CB56119-09C5-38FD-8FDC-064E3CC5068B> /System/Library/Frameworks/GSS.framework/Versions/A/GSS 0x9a98b000 - 0x9aa27ffe com.apple.PDFKit (2.7.8 - 2.7.8) <2DFB71DA-158B-375B-AA75-532AF883EAAA> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit 0x9aa28000 - 0x9aa28fff com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <B95984A1-6C16-338A-9B60-D4F080924243> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x9aa29000 - 0x9aa57fe7 libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <5B70008D-4EA0-30E7-AC12-787D720CEE96> /usr/lib/libSystem.B.dylib 0x9ab6d000 - 0x9ab6fff7 libdyld.dylib (195.6.0 - compatibility 1.0.0) <1F865C73-5803-3B08-988C-65B8D86CB7BE> /usr/lib/system/libdyld.dylib 0x9ab70000 - 0x9ae72fff com.apple.CoreServices.CarbonCore (960.25 - 960.25) <C613B0DA-B401-3DC7-B626-6E20D4DDC8A8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x9ae73000 - 0x9ae74ff7 libquarantine.dylib (36.7.0 - compatibility 1.0.0) <46980EC2-149D-3CF7-B29A-401FB89C275D> /usr/lib/system/libquarantine.dylib 0x9aeae000 - 0x9aeb5ff7 libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib 0x9aeb6000 - 0x9aeb6fff libffi.dylib (??? - ???) <58A2AA81-461E-3581-9A8C-880A3BDA2D6A> /usr/lib/libffi.dylib 0x9aeb7000 - 0x9af77ffb com.apple.ColorSync (4.7.4 - 4.7.4) <61203FBE-54F0-3034-B7EF-25D885D89661> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x9af78000 - 0x9af7aff9 com.apple.securityhi (4.0 - 1) <824838E4-096E-3A3A-AE3C-88D0B1073300> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x9af9f000 - 0x9af9ffff com.apple.Cocoa (6.6 - ???) <30E6ABEE-B390-3C02-8C76-9C62F19FAA83> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x9b2c0000 - 0x9b328fff libc++.1.dylib (28.4.0 - compatibility 1.0.0) <B24814AB-CA77-3B9D-8FAB-58C9B4FD3A16> /usr/lib/libc++.1.dylib 0x9b329000 - 0x9b346fff libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <2870320A-28DA-3B44-9D82-D56E0036F6BB> /usr/lib/libresolv.9.dylib |
#19
0x9b347000 - 0x9b3e3fff com.apple.ink.framework (10.7.5 - 113) <05CAFB64-D3B8-3973-87EA-CB8BBE580F6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x9b3e4000 - 0x9b3fdffb com.apple.ScriptingBridge (1.2.1 - ???) <E96F797B-B0CD-327E-867D-77B9A8A6A1E6> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge 0x9b3fe000 - 0x9b3fefff com.apple.Accelerate (1.7 - Accelerate 1.7) <2112D5A4-7A37-352A-9291-2A6BBA2B34B9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x9b3ff000 - 0x9b3fffff com.apple.vecLib (3.7 - vecLib 3.7) <656463C6-AD21-38FF-B68C-2A7F7922113E> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib 0x9b42e000 - 0x9b4c5ff3 com.apple.securityfoundation (5.0 - 55116) <8A08978E-0705-393D-8AA8-8F59FC6B3C6B> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation 0x9b4d1000 - 0x9b55bffb com.apple.SearchKit (1.4.0 - 1.4.0) <F2583C09-86DB-33CD-A933-F3B8A70CF9A2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x9b951000 - 0x9ba0eff3 ColorSyncDeprecated.dylib (4.6.0 - compatibility 1.0.0) <A31C444A-33EC-3FF2-9E57-F7D1DC521905> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib 0x9ba0f000 - 0x9ba12ff9 libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <16DCE20A-9790-369A-94C1-B7954B418C77> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib 0x9ba1f000 - 0x9bb07fff libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <1841196F-68B5-309F-8ED1-6714B1DFEC83> /usr/lib/libxml2.2.dylib 0x9bb08000 - 0x9bb08ffe libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib 0x9bb5e000 - 0x9bf52feb com.apple.VideoToolbox (1.0 - 705.94) <8FCC2C08-2D4C-3A96-B57A-CAA56911120F> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox 0x9bf53000 - 0x9bf82ff7 libsystem_info.dylib (??? - ???) <37640811-445B-3BB7-9934-A7C99848250D> /usr/lib/system/libsystem_info.dylib 0x9bf83000 - 0x9c385ff6 libLAPACK.dylib (??? - ???) <687048BD-EA20-3C20-B848-B6D730F58281> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x9c386000 - 0x9c3e1ff3 com.apple.Symbolication (1.3 - 91) <6E8D2927-5400-327B-9DA2-400353A01CD1> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication 0x9c3e2000 - 0x9c432ffa libTIFF.dylib (??? - ???) <9511A31E-070C-313E-8320-AAB683AD0653> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib 0x9c478000 - 0x9c483fff libkxld.dylib (??? - ???) <14E79D7A-B6C2-35C5-B56D-D343BEC2A106> /usr/lib/system/libkxld.dylib 0x9c484000 - 0x9c4c4ff7 com.apple.NavigationServices (3.7 - 193) <3D4DFBC6-926F-3883-9235-CDB09340C6A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices 0x9c4c5000 - 0x9c4d0ffb com.apple.speech.recognition.framework (4.0.21 - 4.0.21) <A1764D2F-EB84-33DC-9ED5-CDA3B468FF3E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x9c4d1000 - 0x9c4d2fff com.apple.TrustEvaluationAgent (2.0 - 1) <CE0A7AC9-ACB9-3554-BAAC-1FDEF07E6707> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent 0x9c506000 - 0x9c56bff7 libvDSP.dylib (325.4.0 - compatibility 1.0.0) <2AB35EAF-CB90-3456-BFC8-C14B04C4CA9C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x9c57c000 - 0x9c591fff com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <A20A59DB-33A8-3E9B-B662-45A8876965D4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x9c592000 - 0x9c5daff7 com.apple.SystemConfiguration (1.11.3 - 1.11) <13DBFACD-29A9-32B9-9847-40DB1E85831E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x9c628000 - 0x9cf5372b com.apple.CoreGraphics (1.600.0 - ???) <DD7CDD67-FC4F-36FE-962F-2EA7EF3FC780> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics External Modification Summary: Calls made by other processes targeting this process: task_for_pid: 3 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 1300 thread_create: 2 thread_set_state: 0 VM Region Summary: ReadOnly portion of Libraries: Total=252.8M resident=176.4M(70%) swapped_out_or_unallocated=76.4M(30%) Writable regions: Total=137.2M written=10.5M(8%) resident=35.1M(26%) swapped_out=0K(0%) unallocated=102.1M(74%) REGION TYPE VIRTUAL =========== ======= ATS (font support) 32.0M ATS (font support) (reserved) 4K reserved VM address space (unallocated) CG backing stores 1112K CG shared images 1224K CoreGraphics 8K CoreServices 3728K MALLOC 60.5M MALLOC guard page 48K MALLOC_LARGE (reserved) 10.0M reserved VM address space (unallocated) Memory tag=240 4K Memory tag=242 12K Stack 69.6M VM_ALLOCATE 16.1M __CI_BITMAP 80K __DATA 13.9M __DATA/__OBJC 248K __IMAGE 528K __IMPORT 68K __LINKEDIT 50.3M __OBJC 2516K __PAGEZERO 4K __PDSIG 280K __TEXT 202.5M __UNICODE 544K mapped file 111.9M shared memory 312K shared pmap 7604K =========== ======= TOTAL 584.6M TOTAL, minus reserved VM space 574.6M Model: MacBookPro9,2, BootROM MBP91.00D3.B08, 2 processors, Intel Core i5, 2.5 GHz, 4 GB, SMC 2.2f38 Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In, 384 MB Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80CE, 0x4D34373142353737334448302D434B302020 Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80CE, 0x4D34373142353737334448302D434B302020 AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xF5), Broadcom BCM43xx 1.0 (5.106.198.19.22) Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports Network Service: Wi-Fi, AirPort, en1 Serial ATA Device: TOSHIBA MK5065GSXF, 500.11 GB Serial ATA Device: MAT[bleep][bleep][bleep][bleep]ADVD-R UJ-8A8, 7.63 GB USB Device: hub_device, 0x8087 (Intel Corporation), 0x0024, 0x1d100000 / 2 USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0x1d180000 / 3 USB Device: BRCM20702 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x1d181000 / 6 USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821d, 0x1d181300 / 7 USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0252, 0x1d183000 / 5 USB Device: IR Receiver, apple_vendor_id, 0x8242, 0x1d182000 / 4 USB Device: hub_device, 0x8087 (Intel Corporation), 0x0024, 0x1a100000 / 2 USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0x1a110000 / 3 USB Device: iLok, 0x088e, 0x5036, 0x14100000 / 1 |
#20
Did anything change on this Mac recently?
If the hang is while the message is "looking for varifi.dmp". Then oops yes prefs and databases are definitely worth clobbering. Make sure you are following the instructions and finding all the files exactly as described (I know you already solved the hidden user lib thing). Follow everything exactly including emptying the trash, then restarting the computer. Also do a repair disk permissions on your boot partition. Do a Command-I on the varifi.dpm file in the Finder, what version is it? You have this from the D-Fi plugins that came with Pro Tools 10, right you did no say reinstall the old D-Fi plugins? What happens if you move varifi.dmp out of the Plugin Folder? Then trash preferences and databases. Does Pro Tools get any further at startup. BTW I think I've seen problems where the previous file that loaded causes problems so I'd try to move that aside temporarily as well. I know you tried resinstalling before but did you do this?... unisntall Pro Tools with the clean option, manually remove any plugins left in both plugin folders, reboot and run the installer again. See if that works OK, if so carefully reinstall all plugins *using* their installers--don't just drag the individual files back). And test frequently while doing this. If you have already done that and/or it does not work I'd go for an OS X reinstall. maybe doing something like a full clean install of OS X 10.8.5 on a spare external disks. Boot that, make sure it works OK then install the latest Pro Tools 10 on it and see if it works OK. |
Massive "Buffer Underflow" Errors with Mbox Pro 3rd Gen on MacPro | David Ziegler | macOS | 18 | 12-11-2014 02:49 AM |
pc switch causes massive errors | AttemptD | Windows | 4 | 10-17-2013 08:56 AM |
Crash Crash Crash Live 6 Pro Tools Rewire | TimmyP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-12-2007 11:26 AM |
PT 7.2cs1 crash with DAE -6004 and -11002 Errors | cpunthank | Post - Surround - Video | 6 | 10-01-2006 02:06 AM |
Massive -9019 errors! | Allan Speers | Pro Tools TDM Systems (Mac) | 2 | 08-16-2002 06:07 AM |
