Old 10-16-2013, 02:37 AM
7thheaven 7thheaven is offline
Default Plugs needed before I upgrade AAX
I need solutions for these plugs before I can upgrade.. any suggestions?
TC Master X
Amp Farm
Echo Farm
Syncronic - this is a digi app, why are they not doing this one?
TONS of synth RTAS plugs... they need to allow a wrapper
Richie- 7th heaven
www.7thheavenband.com
Old 10-16-2013, 06:27 AM
DetroitT's Avatar
DetroitT DetroitT is online now
Default Re: Plugs needed before I upgrade AAX
Nothing will be a true replacement.
Especially for the unique like Syncronic.
TC Master X: McDSP, Waves, Izotope
Amp Farm: Waves GTR, Eleven
Echo Farm: Waves H-Delay, Papen RP Delay
Syncronic:Turnado (SugarBytes) (Looper slicer)
Wrappers are now effectively replaced by Plug-in-Hosting for VST plug-ins.
The most stable I've found is the BlueCat MB7
And or parallel apps like Vienna Ensemble Pro, Reason
Old 10-16-2013, 06:50 AM
JFreak's Avatar
JFreak JFreak is online now
TC Master X
Amp Farm
Echo Farm
All of them are in the not-gonna-happen list, so your solution will be staying in the PT10 land or finding out how you can replace the four plugs.
Janne
Old 11-25-2019, 03:02 AM
so far 2 of them have been ported... any suggestions of replacements for syncronic? and why is tc electronics ignoring the finalizer for aax... they would sell a ton
Richie- 7th heaven
Old 11-25-2019, 05:43 AM
jre3132 jre3132 is offline
Echofarm and amp farm are finally good to go for aax. I used to use masterx3 on EVERYTHING (master fader). I'm not a huge fan of how MCDSP has been operating lately, but the ML series is a pretty good substitute. From waves I use the L2 or L3 multi which also work well for a similar effect.
Mac Pro 3.7 Quad Core Intel
Mac OS X 10.13.2
PT Ultimate HDX 2019.10
64GB RAM
HDX I/O 16x16 Analog
HDX I/O 8x8x8
Old 11-25-2019, 05:49 AM
Originally Posted by DetroitT View Post
snippage
Simpler from Blue Cat would be Patchwork; that way you don't have to deal with band splits like in MB7. I have both and unless I need to do some multiband work I'll use Patchwork for hosting.
Be wary of Reason. With Reason 11 they dropped Rewire support and when used as a plugin in a daw you can't host external plugins in it. And R11 doesn't have an aax version.
And if you're on a Mac VEPro 7 which is the current version has dropped the ability to work with 32 bit plugins. Windows users are lucky in that they still have 32 and 64 bit support in VEPro 7.
Jack
QAPLA!
HTML code is On
how can I upgrade my old tdm plugs to AAX? musicmixer04 Pro Tools 10 8 01-19-2012 10:40 AM
How can I upgrade the FF d2 d3 plugs that I own SteveGarman Pro Tools TDM Systems (Mac) 4 09-21-2011 09:49 PM
Help Needed - Producer Factory Pro Plugs don't work ppisnow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-04-2009 06:50 AM
>URGENT HELP NEEDED = Waves plugs < megahurt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-20-2004 12:42 PM
Do i have to upgrade my plugs?? CaP I.M.S 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-28-2002 09:52 AM
