Old 10-15-2013, 11:51 AM
AttemptD AttemptD is offline
Default pc switch causes massive errors
Hello peeps. I'm new to this forum and I apologize for any ignorance I may portray. Anyways.
I've been using protools 9 with an mbox 3 pro for a while...I'm about to upgrade to protoola hd native with an Omni...but that's another siutation.
I've recently rebuult my pc....I'm using the same ram...peoceasor...bur I've switxhed hard drive and motherboard...and added a more high end video card....that is all....
And NOW protools is a nightmare compared to what it was...:/
I get errors on the regular. Ill open up just 1 track with a VI plugin (Ivory) for example. And every few seconds it has I need to decrease my buffer rate or remove things from my firewire bus. If I run ten or twelve tracks with a few plugins each.BAMN runtime error. Sometimes I get random erroras about me running out of cpu power....ouch
None of this makes sense...
Beforehand I could have tracks for days. And VIs, evwn higher end samples, weren't even CLOSE to the issues theys are now. Usually have at least four or five running with tons of other tracks and plugins....without issues....and now I can do nothing.......once again....I'm about to ger a HD system. ...but I don't want more problems like this in the the future. ..
If anyone could guide me it'd be greatly apreciated....thanks for letting me be a part of your community.
Custon build
Windows 7 64-bit
i7 8core 3.2 ghz
12gigs ram
Nvidia gtx 770
500 gig primary hard drive
1000 gig secondary hard drive.
Old 10-15-2013, 02:48 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: pc switch causes massive errors
What Motherboard, Hard Drive and Video card are you now using?
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 10-15-2013, 07:24 PM
Thanks for the reply.
My video card is a EVEA Geforce gtx 770 2gig DDR5
New motherboard is a MSI Z77A-G45 (military class III)
I cant say for sure on my hard drive....but it was an old one I seemed to have used in the past with my old protools 8 mbox 2 setup.
Thanks again :)
Custon build
Windows 7 64-bit
i7 8core 3.2 ghz
12gigs ram
Nvidia gtx 770
Old 10-17-2013, 08:45 AM
Does anyone know anything???? Or can someone at least push me in the direction of someone who can?? I really don't know what to do. :/
Thanks
Custon build
Windows 7 64-bit
i7 8core 3.2 ghz
12gigs ram
Nvidia gtx 770
Old 10-17-2013, 08:56 AM
Southsidemusic's Avatar
Thanks
What are your harddrives rpm and cache? RAM? Other Peripherals connected to the computer? We need a lot more info as this can be caused by loads of things and sometimes it all comes down to the drives. Have you downloaded the absolute latest drivers for the Mbox? Sorry for all the questions but we need the made/model/rpm/cache size of all your hard drives aswell as how they are set up? Like which one is for recording to, which one is OS drive, do you use lots of samples and if so, do you have a dedicated sample drive or where are the samples located?
Best
Chris
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Massive "Buffer Underflow" Errors with Mbox Pro 3rd Gen on MacPro David Ziegler macOS 18 12-11-2014 02:49 AM
Pro Tools 10.3.4 MASSIVE Crash Errors sascjosh General Discussion 24 01-15-2014 01:59 AM
External talkback mic/switch/cuelight switch Pete Gates Post - Surround - Video 3 03-16-2011 01:53 AM
Switch Mac Mbox to Windows - and then switch back bluesigns 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-07-2004 09:50 AM
Massive -9019 errors! Allan Speers Pro Tools TDM Systems (Mac) 2 08-16-2002 06:07 AM
