Questions on USB/Firewire speeds on computer W/ No firewire port
I am currently upgrading my audio interface, maybe a Focus rite or Apollo or something along those lines. My Windows PC does not have a firewire port on it. It sucks because some of the best interfaces I looked at are only firewire. I've looked online, and I guess the max speed of data transfer for USB is 480mbps, while Firewire is almost twice that. My question is, would it be okay to use a firewire to USB adapter with the interface, or would it interfere with data speed between the interface and computer, and possibly cause pops, clicks, lag etc. Also, if there are any recommendations on how to use firewire with usb that would be helpful.
Re: Questions on USB/Firewire speeds on computer W/ No firewire port
Don't do it. Most likely will cause more headaches then it's worth. You can add Fire wire ports to you computer via the PCI-E Slots. My Computer didn't have Fire wire by default either.
You need to buy a Fire wire card for your computer. For some reason Pro tools is very picky about which chipset you use. The best chipset for use with Pro Tools is a TI Chipset (Texas Instruments). Get one that fits into a PCI-E 1x slot to avoid any bottlenecks. You can also find some cards that are powered using a cable off your computers power supply. This way you can have multiple Fire wire ports if needed and you can get a combination of FW 400 and FW 800 ports so you can connect to any interface that uses Fire wire. Should be able to pick one up for around $40-50, good luck! |
Here to make this a little easier, I found the card I use on Newegg. I can verify 100% this card works with Pro tools. I use my Presonus interface through it daily:
http://www.newegg.ca/Product/Product...82E16815287011 this would be the slot you take the pre sut metal plate out for. The PCI-E 1x slot is the smallest of the expansion slots, alot smaller then the one you would install a graphics card into. It is dead simple to install you just plug and play |
You got it man, that's how it works, Good Luck!
Thanks so much man. Haha I was about to just throw my laptop at how frustrated I was as to what firewire is, and if I can only use a USB interface. Now since I know my computer does have the slots you mentioned, I can buy the card, look at both USB and firewire interfaces and have the best of both worlds and more options to choose from since it sounds pretty painless with the installation.
Once again thank you I really appreciate it :) |
Help us Help You - READ THIS Before Posting! If you read this link and post a Sandra report, that should tell us what we need to know about your computer.
Cool More info at this link:
http://www.geeks.com/techtips/2006/t...s-24sept06.htm
Impossible to find SIIG FireWire 2-Port ExpressCard FireWire adapter | Bloody Maker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-22-2010 09:58 AM |
FW410 Risky Firewire Problem ? or Not ? Firewire risky port ??? | jaunmanuek | Pro Tools M-Powered (Win) | 2 | 02-24-2009 06:22 AM |
firewire port | arnobg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-19-2009 09:15 AM |
2 Firewire devices.1 firewire port (macbook pro) | TBF Entertainment | Pro Tools M-Powered (Mac) | 10 | 09-16-2006 01:28 PM |
How can you use an external firewire drive and Digi002 with only 1 firewire port? | CraigD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-16-2003 01:11 AM |
