release date for HDX ?
Anyone knows when the HDX card will hit the stores. Need to upgrade my HD3 ASAP. Thanks
Re: release date for HDX ?
Sweetwater's site lists next week as when they arrive.
You do know that you can do a pre-order, right? |
December 15, in Dk.
Mikkel |
How significant an upgrade is HDX from HD3 (assuming a one-card HDX system)? Digi's own numbers on this show 18 x 350 MHz for an HDX card, 3 x 9 x 200 MHz for an HD3 Accel. Given that the HDX card is working on 32-bit files, it would seem the HD3 Accel has the edge, by about 14%. I'm sure there are other considerations (as Avid claims "3x-7x the power per card"), but on the face of it, it looks like you would get a small downgrade in performance.
Does anyone else know whether I'm off-base here? |
HDX cards are not the problem but PT 10.1 that supports HDX cards won't be available before mid-January.
http://www.protoolsprofessional.com/...the-winner-is/
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
For me the most interesting question is not how much more powerful is HDX than HD1 since even PT10+CPTK already out-powers an HD3 or is at least equivalent (apart from the latency).
The only difference between PT10+CPTK and HDnative is that the card provides the I/O to an AVID-Interface. Both systems rely on native processing 100%. So apart from the interface they do compare, which is why I mentioned it. I know that the article doesn´t mention PT10+CPTK but I doubt that you will see a huge difference when you open than test-session on PT10+CPTK. But would be worth a try.
Release Date Set For Release - To Be Released Soon | rockrev | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 10-30-2005 05:51 AM |
PT7 Release Date??? | Matt Whritenour | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-26-2005 04:10 PM |
PT7 release date | skylab001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-14-2005 01:05 PM |
Release date on 5.1??? | GreyArea | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-27-2000 12:29 AM |
PT 5.0 release date & G4 | Gremz | General Discussion | 4 | 10-14-1999 02:26 PM |
