All Digital Parametric EQ’s are the same
MacPro 12-Core, 48 GB RAM, OS 10.12.6, PT Ultimate 2019.12.0 HDX, Antelope Orion32HD III http://17-studios.com |
Re: All Digital Parametric EQ’s are the same
Many times discussed here.
In general it's true as there are only 3 controls and they must be precised mathematically - Freq, Q Factor, Gain. Many talks are about the filters slope too. EQ's are the same and the same sound can be achieved if their versatility can allow this. Some EQ's have not wide / nerro enough Q factor or Gain limitation to 6, 12, 24 dB A different story when saturation plugin is built in EQ McDSP Filterbank (called analog curve), SoundToys Filterfreak, Renaisance EQ e.t.c
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 |
MDW Hi-Res Parametric EQ Demo | MatthieuH | RTAS & TDM Plug-ins | 6 | 12-05-2013 04:54 PM |
MDW Hi-Res Parametric EQ v5 is now available | Avid | Technical Alerts | 1 | 08-24-2012 12:55 PM |
Help needed about Parametric EQ on 11R | Alp | Eleven Rack | 24 | 08-15-2011 06:07 PM |
Parametric EQ recommendation | DJ Robby Rabbit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-05-2006 11:02 AM |
What is Q in a parametric? | dummy20707 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-22-2002 08:03 PM |
