Go Back   Avid Pro Audio Community > Legacy Products > Aspera DigiDelivery
Old 11-16-2009, 11:36 AM
Phill Barrett Phill Barrett is offline
Default Problem with Digidelivery client on one Mac
I have 2.1.1 client installed on several different Macs and all work fine except one. The problematic one starts fine, but after a while either the DD client quits, becomes unresponsive, or just never completes the delivery. This occurs both to the local DD server (ie on the same local network) or to external servers. The Mac is an Intel running the latest version of Leopard (ie. not Snow Leopard) on a Gb network and all other network traffic seems fine to and from this machine. I've tried deleting the Digidelivery directory & reinstalling the DD client, but the problem still occurs. Occasionally the delivery will succeed, but more ofthen than not it fails. If the files are copied to another Mac the delivery is then sent fine from that machine.
Any ideas what might be causing this or what to try to get the DD client to work reliably?
Thanks,
Phill.
Old 12-08-2009, 03:38 PM
Default Re: Problem with Digidelivery client on one Mac
OK, make that two clients refusing to reliably connect now. I can't think of anything that's changed, or anything that's different between those Macs that the Digidelivery client is reliable on and those that its not. I guess though I'm assuming its a networking thing when it might just be the clients failing internally for some reason. All network transfers between machines works fine and reliably across the gigabit lan, this onlyt seems to affect Digidelivery.
DigiDelivery client? JonesH Aspera DigiDelivery 2 08-01-2013 12:46 AM
Digidelivery client stalling or failing blairl Aspera DigiDelivery 10 11-19-2007 05:50 PM
DigiDelivery Client won't launch TomMxEdit Aspera DigiDelivery 5 09-09-2007 09:13 AM
DigiDelivery Client switch accounts KingTor Aspera DigiDelivery 2 09-12-2006 02:10 PM
Digidelivery Failure (client) Rick Sanchez Aspera DigiDelivery 1 04-21-2006 06:13 PM
