Old 07-01-2002, 01:13 AM
Allan Speers Allan Speers is offline
Default Massive -9019 errors!
I upgraded from a G3 to a G4 about a month ago, for my protolls Mix system.
I had very few problems before. Now I am having CONSTANT disk-too-slow errors. Several numbers pop up, by -9019 seems the most common.
I am crashing about once every 15 minutes.
Oddly, I transferred some sessions to my start-drive, just to do some editing. The problem did not change, exactly the same.
I can't find any help on the Digi site, nor in a DUC search.
Any ideas at all?
Old 08-15-2002, 04:16 PM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
Default Re: Massive -9019 errors!
I've been getting -9019 fragmented errors in certain points in my sessions. (Machine locks up, usually hand comes up, in the same spot +/- 5 frames)
I've tracked the problem down to corrupted automation data in stereo tracks. (I don't have any plug-ins) When I delete all pan automation (including position, divergence and centre %) and re-do any volume automation that is there (about 2 seconds after the point at which it crashed) the problem goes away. I've also noticed that some automation dots look like they're a bit "fat" - like two are stuck very closely side-by-side.
Oh also the problem seems to come up in the first place when clips are moved from track to track with the grabber.
Hope this helps,
Mark
PT 5.1.1
OS 9.2.1
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
www.soundsinsync.com
Old 08-16-2002, 06:07 AM
DigiTechSupt's Avatar
Here are a couple of suggestions:
-Check the integrity of your drives with Disk Warrior or any other such utility. Repair any and all corrupted catalogs and/or BTree Directories
-Increase the Preferred Memory sizes of DAE and Pro Tools. Values of 90MB and 80MB respectively should suffice. Be sure that the Minimum memory sizes stay at their default settings.
-Rebuild the Desktop files for all drives.
-Trash the DigiSetup File, Pro Tools preference, and DAE prefs (the entire folder) from the System Folder>Preferences folder. Empty the Trash and restart the Mac.
-In Pro Tools, open the Setups>Preferences>Operations window and limit the “Open Ended Record Allocation” to 10-30mins.
Brent
Avid Audio Tech Support
Support FAQ
9073 and 9019 errors kevon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 02-23-2011 12:56 PM
9019 and 9073 errors? HDK_Ent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-04-2010 04:05 PM
DAE Errors 9073 & 9019 shoalbilly Digidesign Hardware & Software 2 11-29-2004 09:07 AM
9019 and 9073 errors juice 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-03-2003 02:12 PM
-9019 errors with FWB FW drivers Pindy Pro Tools TDM Systems (Mac) 5 12-10-2001 11:09 AM
