Syncing Protools 7.4 and Logic 8 via MMC IAC bus
I can't seem to get Protools 7.4 and Logic 8 to sync via MMC. Logic slaves just fine to protools but I can't get protools to be controlled by logic. Any help would be apreciated.
Thanks |
Re: Syncing Protools 7.4 and Logic 8 via MMC IAC bus
I've never gotten good results with ProTools chasing SMPTE (MTC) from Logic. Set it up so Logic follows the clock from PT, and PT receives MMC commands from Logic. I also use a hardware cable (out one port, into another) for the clock. This is for running both on the same machine.
Also, this isn't scientifically totally tested, but I've had better luck with Midipipe (free) in general than with the built-in Apple IAC. Good luck
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur |
Sorry if I misread your post (I was in a hurry). Try what I said in my post (SMPTE one way, MMC the other). That's what has always worked for me.
The last time I checked, ProTools would not respond to MMC messages coming in via the IAC bus.
It does work if you make external cable connections on a MIDI interface- clumsy, but do-able. Incidentally, don't expect the accuracy of your sync to be better than +/- a few hundred samples (maybe this has improved- haven't tried this since Structure came out ) |
Help! Can't hear audio when syncing protools to logic | MX582 | Pro Tools TDM Systems (Mac) | 2 | 01-31-2010 07:18 PM |
Syncing protools to Logic | Josh_eg112 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-19-2009 09:53 AM |
Syncing logic to protools 1 computer | garfield mead | Pro Tools TDM Systems (Mac) | 19 | 01-27-2009 01:56 PM |
Logic 5.5 Protools 6.1 crashing when syncing | aftermid | Pro Tools TDM Systems (Win) | 5 | 10-31-2005 08:27 AM |
Syncing protools to logic 6 | Thresholdproductions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-30-2004 10:27 PM |
