DigiDelivery Client won\'t launch
Hello forum,
I am having trouble with DigiDelivery Client. When I try to launch, I immediately get the crash menu "The application DigiDelivery quit unexpectedly." etc. I have tried downloading a new copy of the application. I tried using the pre-binding utility, Cocktail, restarting, etc. Nothing has fixed it so far. Are there some preferences I might toss? If so which ones? I am using Mac OS 10.4.10, which I downloaded with the combo software, not software update. Might this be the problem? I will go to another computer to use my DigiDelivery server, but would like to be able to run it from this computer eventually. Thanks in advance for any help. Tom Carlson |
Re: DigiDelivery Client won\'t launch
There is something that 10.4.10 update breaks. I don't have DigiDelivery, but after I upgraded (combo update) I could 'see' all my network computers but when I double-clicked them it said the alias was broken. Are you able to log in to the other computers on your LAN? In my case reinstalling the 10.4.10 combo update fixed it for me.
Good luck!
http://www.ripplefx.com Mac Pro 8 core 3.0GHz Harpertown Magma PE6R4I - HD 3 Accel +1 Process Control 24 - 96io - 1622 OSX 10.6.8 - PTHD 10.3.10 |
Thanks ripple FX for that suggestion. Unfortunately, that didn't fix it. I'll contact support by phone today.
Tom |
You should try trashing the preferences file named 'com.digidesign.digidelivery.plist', empty the trash and restart.
Thanks Tech Support for the reply. I tried trashing the prefs per your suggestion. Unfortunately that did not fix the problem. I have run the prebinding script app which also did not fix the problem. Any other suggestions?
Tom |
Well, the problem has been solved (thanks to Koji Egawa for the suggestion). It was the file:
Home folder -> Library folder -> Caches folder -> com.digidesign.digidelivery folder that was the culprit. I deleted that file and the preferences file and folder and restarted and that solved the problem. Tom Carlson |
DigiDelivery client? | JonesH | Aspera DigiDelivery | 2 | 08-01-2013 12:46 AM |
Problem with Digidelivery client on one Mac | Phill Barrett | Aspera DigiDelivery | 1 | 12-08-2009 03:38 PM |
Digidelivery client stalling or failing | blairl | Aspera DigiDelivery | 10 | 11-19-2007 05:50 PM |
DigiDelivery Client switch accounts | KingTor | Aspera DigiDelivery | 2 | 09-12-2006 02:10 PM |
Digidelivery Failure (client) | Rick Sanchez | Aspera DigiDelivery | 1 | 04-21-2006 06:13 PM |
