Go Back   Avid Pro Audio Community > Legacy Products > Aspera DigiDelivery
Old 01-23-2007, 07:19 PM
BaseHead BaseHead is offline
Default DigiDelivery Failing about 60% of the time
I'm hooked to Paramount's DD system for this movie i'm working on and it keeps tanking.
It goes for a while on these large video files and then says "Failed"
It never tries to resume. What's up with that?
This in on XP Pro
Below is a log of some of them
I've gotten 7 Failures and 4 Success's so far
if it makes it past the first 20-30% mark it seems to work.
any ideas?
s>
DigiDelivery History
Delivery
Type
Date and Time
Status
C39 R6v1_19
Receive Tue Jan 23 18:39:55 2007 Failure
Size:
1843219348
Sender:
Dana Frankley
Location Saved:
H:\C39 R6v1_19 2
Error:
GetLastError returned 183
C39 R6v1_19
Receive Tue Jan 23 18:20:22 2007 Failure
Size:
1843219348
Sender:
Dana Frankley
Location Saved:
H:\C39 R6v1_19 1
Error:
Stevie use this for 5v1/19 omf
Receive Tue Jan 23 14:35:22 2007 Success
Size:
8036864
Sender:
Dana Frankley
Location Saved:
H:\Stevie use this for 5v1_19 omf
Old 02-08-2007, 05:36 PM
Default Re: DigiDelivery Failing about 60% of the time
Wow!!
Great Tech support here!
not one response from the company
Glad I didn't pay $8,000 for the system
I reset my routers and thought that fixed it, but it's still doing it.
So I switched to FOLDERSHARE instead.
Works perfect and resumes like a champ if you ever get disconnected or have to re-boot
and it's FREE
s>
Old 02-22-2007, 11:16 PM
KingTor KingTor is offline
I've had a few problems with that, but nothing like 60% of the time. I have had the client unexpectedly quit a few times, though, which is even more maddening than "failing," although the outcome is the same.
I was also recently working with someone downloading from my server and his client software would start downloading and acting as though it had finished in less than a second but, obviously, the files weren't actually downloaded. Rebooting his computer seemed to fix the problem.
Is anyone else having the client software fail and/or crash? Are there any known issues with the client software that are scheduled for fixes? I'd love to get to the bottom of this.
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
Old 03-21-2007, 03:06 PM
Gordon Lyon Gordon Lyon is offline
If you are having problems with DigiDelivery, it's best to email [email protected] for support.
I happen to know that Paramount may have particular issues with their network. You should contact the system administrator at Paramount (or whomever you're working with there) to see if they can help you with this problem.
Thanks, Gordon
Old 11-11-2008, 03:49 PM
jdeas jdeas is offline
While I can see sending an email, by not posting the solution here anyone with this problem (including me) has to wait for an email return from Digi. You work there. Is there some reason Digi would not post the answer here and it not, is this simply a client to client support area?
Old 11-11-2008, 07:32 PM
Craig F Craig F is offline
maybe because Digi sold the product off to Aspera?
Thank you,
Craig
Old 11-12-2008, 08:53 AM
DigiTechSupt's Avatar
jdeas -
Craig is correct - Aspera now owns DigiDelivery and the reason Gordon posted what he did at the time was that we did not have a tech monitoring the DUC full time and a direct email to tech support for the DigiDelivery would get a reply usually within a few hours.
Also, I think he did give the solution - or rather the reason for the problem:
At the time this was occurring we were working with Paramount and their ISP to help their ISP make the necessary configuration changes to their network to get DigiDelivery working properly.
If you do need assistance with a DigiDelivery server, please contact Aspera directly:
Effective September 21, 2007, Digidesign no longer provides Technical Support & Service for the DigiDelivery product line: Aspera Inc. To Acquire DigiDelivery Product Line press release.
Aspera will assume all ongoing DigiDelivery development, manufacturing, sales, and support. Please use the following contact information for all DigiDelivery support:
Aspera Technical Support
www.asperasoft.com/support
Avid Audio Tech Support
Support FAQ
S5MC - MC PRO failing ErikGuldager System 5 4 08-14-2013 11:15 AM
Digidelivery client stalling or failing blairl Aspera DigiDelivery 10 11-19-2007 05:50 PM
Using Digidelivery for the first time sheldon013 Aspera DigiDelivery 1 03-06-2006 09:22 AM
Digidelivery..........Used it today, first time! Stompinmsc Aspera DigiDelivery 17 03-20-2005 09:04 AM
DSP failing Whisky Digidesign Hardware & Software 0 07-07-2000 07:44 AM
