Old 02-14-2005, 01:54 PM
FinnJ FinnJ is offline
Default Behringer DDX3216
hi
what the best way to hook up the behringer ddx3216 to use it as a mixer?
Old 02-14-2005, 02:00 PM
Bastiaan Bastiaan is offline
Default Re: Behringer DDX3216
with 2 adat-cables and spdif. That way you get 10 channels up and down. Make one the masterclock, and let the other slave to the incoming signal to prevent pops and clicks.
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 02-14-2005, 02:03 PM
do i need to get extra bits then other than the 002R to make this work or just the 2 adat-cables and spdif? will this allow the flying faders to work?
Old 02-14-2005, 02:26 PM
eh....
You asked to be able to use the ddx3216 as a mixer. That way you CAN use it as a mixer for ptle. What i think you want is to use it as a control-surface, wich is a different story. Get the manual, and get the midi-controllerguide from Digidesign, and make it perform as a JLCooper CS-10 or some other controller Protools can work with.
What's that?
Bastiaan
Old 02-15-2005, 11:45 AM
sorry if i seem a little confused about all this.
if i hook into the mixer using just the spdif will i just get 2 channels on the mixer? also im presuming that to hook into the adat on the mixer i would have to i would have to buy the adat card for the mixer, am i right? and does the spdif or the adat control the wordclock
i wanto use it for pro tools but i also want to be able to use it as a live desk, are there any other alternatives?
thanks guys
john
Old 02-15-2005, 12:32 PM
Chad Knowles Chad Knowles is offline
I looked at that mixer, I was going to use it as a control surface and mic preamps via lightpipe. You will have to connect midi if you want to use it as a control surface. It seem to do everything the JL Cooper will do, faders and encoders, but I am not sure about plug in automation. I could not find any support for using it with ptle.
In short if you use it for the preamps use lightpipe in and out and spdif. For control surface use midi in and out. Hope thais helps. I have heard midi is better in pt6.7.
Behringer DDX3216 with Pro Tools Palli-Moon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-25-2005 06:26 AM
Behringer DDX3216..need help! AM STUDIOS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-03-2005 05:31 AM
Anyone with a Behringer DDX3216 that can help ... ricfoxx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-13-2004 01:11 AM
002R + Behringer DDX3216 Louie Lou 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-20-2004 07:50 PM
Using Behringer DDX3216 as PT controller timtraynor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-08-2002 01:33 PM
