Old 01-21-2005, 12:39 PM
FinnJ FinnJ is offline
Default cpu bar shooting up when track is stopped
hey guys
ive got a song going with about thirteen tracks and about 25 plug ins but my system is teeling me that im running out of cpu power. the song will play fine but when i stop to edit the cpu meter shoots up in the clouds and slows the system down. Is there an issue with the DVERB plug in or the 4 band eq as these are the plug ins that im using
thanks
john
Old 01-21-2005, 12:47 PM
spkguitar's Avatar
Default Re: cpu bar shooting up when track is stopped
Yes, put a dither in line before the DVerb. Search this forum or the web for "denormalization" to find out why.
Chris Cavell Chris Cavell is offline
dither before d-verb to fix it
Cavell Studios
Old 01-21-2005, 12:48 PM
beat me to it...
Cavell Studios
spkguitar's Avatar
Old 01-21-2005, 01:07 PM
thanks lads
anyone know if this fault was sorted in the newer up dates of pro tools?
im still running 6.1
Old 01-21-2005, 01:12 PM
KingFish KingFish is offline
No, it's still an issue with the plugin, and P4 Processors mostly. (not really a PTLE application problem)
Denormalization continues to happen in 6.7 with a few plugins, however, adding dither to the plug's input always seems to fix it.
David
- MacStudio M1
- HDX II Sonnet xMacStudio
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
- ProTools Dock / S1 / Control App
Old 01-21-2005, 01:56 PM
thanks lads
It isn't a "fault" really. Like spk said, look up denormalization to find out more about whats going on here.
Cavell Studios
Old 01-21-2005, 02:32 PM
tele_player tele_player is offline
thanks lads
Respectfully, I'm gonna disagree with you on this, Chris.
I'm a software engineer, have been for a long time. If I write a program which has known problems, in predictable normal situations, and known workarounds, I add the code to handle the situation. If adding a low level of noise to the signal (putting a dither before it) prevents the problem, the plugin should do that internally.
See, in this case, it's not a tradeoff; the task at hand (reverb) is not aided in anyway by the CPU going into denormalization mode, especially if it gets stuck there to the detriment of the system's performance and stability.
Quad 2.5 G5, 4.5G RAM
Old 01-26-2005, 12:54 PM
hi guys
im still have trouble with this, i`ve dithers infront of all my dverbs (bout 4 of them). im running quite a few 4band eqs and compressers (maybe 20 altogether), but the problems only coming up when im working on the track editing
any more ideas? i`ve tryed ,using sends to cut down on the pluggins but its not making a difference
by the way i`ve got a 2.8Ghz dell with 1G of ram
Fast Track Ultra - Main Output Knob Stopped Working danimal423 FireWire & USB Audio Interfaces (Mac) 12 04-18-2013 11:57 AM
click track stopped working. nerhal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-12-2011 11:48 PM
Mac trouble shooting Huesb Pro Tools M-Powered (Mac) 1 09-28-2007 07:45 PM
still freezing up, even after t-shooting daryl eakins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-23-2006 01:32 PM
Import audio to track stopped working tiktok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-06-2005 11:22 AM
