Old 02-16-2020, 11:42 AM
R0b M R0b M is offline
Default Recording Midi with Start and End Selection
If I select a range of measures to record the recorded midi ends up 6 measures later than when I played. Can anyone think of a reason this is happening? I've had this happen in several projects. If I remove the range and just record from a starting location the midi gets placed correctly.
Old 02-16-2020, 12:15 PM
JFreak JFreak is online now
Default Re: Recording Midi with Start and End Selection
Does this happen with all instruments or just some specific plugin?
Old 02-16-2020, 02:06 PM
It doesn't seem to matter. I was using Kontakt so I switched to the Mini Grand and then to Xpand!2. Recording always places the notes 6 measures later than where they were played.
Old 02-16-2020, 02:24 PM
and you are using which OS&PT combo?
Old 02-16-2020, 02:39 PM
MacOS Mojave Version 10.14.6 with Pro Tools 2019.12.0. I also tried adding a different track and it does the same thing. I opened a few old projects and they all have the same problem although the offset isn't always the same. In one project the offset was one measure instead of 6.
Old 02-17-2020, 01:09 AM
TNM TNM is offline
I'll check now and see if I can reproduce.. It could be the midi KB you are using of course but it could be a PT bug.
BRB.
Maybe if a few people can reproduce it then avid have something to go on.
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX
Old 02-17-2020, 01:13 AM
TNM TNM is offline
Yep, reproduced it 100%.
It's broken in 2019.12.
If you highlight a range and play in midi notes, it puts them at the next bar.. you can see as you are playing them that is recording them in a total different area of the track. FRICK!
Edit, workaround is to highlight the range on a different track but just have the record armed only on the midi track. Still.. that's ridiculous.
Old 02-17-2020, 11:01 AM
basehead617 basehead617 is offline
this is absolutely ridiculous
Old 02-17-2020, 11:06 AM
Anyone still using 2019.10, can you confirm it is not broken there?
Old 02-17-2020, 09:09 PM
TNM TNM is offline
I'm in the process of making a little video of it just to clearly show the issue for all.
I'm on the imac right now and only have 2019.12 so can't test a previous.. hopefully someone else can.. I should be able to check out PT 2018 tonight on the HS partition but I no longer have PT 12/Sierra partition on the macbook as I felt I didn't need it anymore.. To be honest I was going to delete the HS partition this weekend and PT 2018 as well.
Maybe 2020 will fix it and they are already aware of it. I would have noticed it though in earlier versions as I use this feature now and then.
Then again, saying they might fix it is like saying they might fix the midi connection project reload bug, which has been there ever since I first used pro tools.. That one boggles my mind that they won't fix it. I am almost never able to reload a project and have it sound as I last left it, I always have to find a couple missing sounds and remake the connections. So the workflow time I save by using PT is sort of negated cause I have to check every project on every reload to make sure it's connected to it's midi out!
Pasting automation to selection, independantly of start selection a_mendritzki Post - Surround - Video 7 06-08-2016 04:01 PM
Edit selection and playhead start Alexander K Pro Tools 10 12 05-30-2013 09:03 AM
How to punch a selection but start playback before the selection... shotgunndunn macOS 1 01-19-2012 04:45 PM
How to move view to start or end of selection Boe Larsen Pro Tools TDM Systems (Mac) 5 03-09-2011 12:48 AM
"Set Selection Start" causes short audio pause...how to fix? Leigh Marble Pro Tools M-Powered (Mac) 4 09-01-2009 02:01 PM
