Old 02-12-2018, 11:25 AM
To Find Solutions To Find Solutions is offline
Default How to know an audio clip frame rate
I need to know the frame rate in which an audio clip was really recorded. I used a zoom f4 and I have chosen the frame rate in 24 fps but in fcp says that it is 23.98 and I want to verify it in pro tools but I don't find any information like this. Is there a way to know the fps of an audio clip in pro tools?
Thank you so much! you're saving my life.
Old 02-12-2018, 11:32 AM
Carl Kolchak Carl Kolchak is offline
Default Re: How to know an audio clip frame rate
Go to the "Windows" drop down menu in Pro Tools, and open Work Space.
You can view all information about an audio file (as well as video files, effects presets, Session files etc) in columns.
Old 02-12-2018, 11:41 AM
Thank you so much for your help. I opened the workspace but in the column of tc rate doesn't appear any information. Any idea of why is this happening?
Old 02-12-2018, 11:42 AM
BScout BScout is offline
Audio has no framerate. This is just a setting in the metadata written by the recorder. Easiest way to read it is with Waveagent (which is free)
https://www.sounddevices.com/product...are/wave-agent
Old 02-12-2018, 12:25 PM
Thank you so much! I'll check it out.
audio frame rate conversion nardo macOS 2 08-16-2012 02:47 PM
Frame rate audio clip converter RuffinMedia Post - Surround - Video 3 07-04-2012 02:55 AM
frame rate on audio file? viaspiaggia Post - Surround - Video 19 07-28-2010 12:38 PM
Audio Frame Rate NTSC to PAL mattcmi Pro Tools TDM Systems (Mac) 3 05-25-2010 12:15 PM
Free Frame Rate and Frame Calc widgets dr sound Post - Surround - Video 1 08-21-2008 11:39 AM
