Old 07-03-2017, 04:36 AM
elicious elicious is offline
Default Re: Bug: When selecting a favorite plugin insert, the plugin above the one selected o
Yep, seen it here as well, in our case with plug-ins from waves…
ihatetyping
Old 07-11-2017, 02:33 PM
Jperkins Jperkins is offline
It would be nice to see a fix for this, or anybody at AVID acknowledge it. The favorites list is nice but it's useless when you have to play guess and check which plugin actually loads.
Not to mention, compared to the way you can search your plugins and organize them in REAPER, the PT plugin management system is weak.
We need the one thing you can do to work!
iMac Pro 3.0GHz 10-Core • 64GB RAM • SSD for OS and audio • MacOS 10.13.3
http://www.mysteryroommastering.com/
http://www.justincarlperkins.com/
Old 07-11-2017, 02:44 PM
john1192 john1192 is offline
we need to be able to reproduce this to show Avid .. can you help me reproduce this ?? as i had said in a earlier posting, i cannot reproduce this here ..
what am i missing ???
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 07-12-2017, 08:24 PM
I'm not sure but it's a real thing reported by multiple users. Maybe try loading more than 3 favorites. Try using multiple vendors.
Here are my PT Prefs if that helps:
https://www.dropbox.com/s/adze5p5t5u...Prefs.zip?dl=0
Did you see my GIF that shows it happening? It's real.
Old 07-12-2017, 08:37 PM
yes i saw what you did ... and yes i loaded more than 3 presets and yes from different vendors ..
still cannot make it happen ... i will keep trying ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 07-13-2017, 04:57 AM
Thanks. At first I assumed it was something on my end but many times I've trashed my prefs and cleared the favorites list to start fresh.
The issue always comes back.
It may be hard to pinpoint because for me it's an intermittent issue. I'd say 1/3 of the time, I don't see the issue but more often than not, when I select something from the favorites menu, a different plugin farther up the list is loaded.
I think I see it more with mono tracks than stere.
Are you testing with a mono track?
Old 07-13-2017, 06:40 AM
i will make sure it is just one mono track in the session and give it another go today ...
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 07-13-2017, 08:23 AM
Thanks. I also pasted a link to my PT Prefs. Somewhere in there should lay the key to reproducing the issue.
It doesn't seem to be tied to one specific plugin.
Old 07-13-2017, 09:49 AM
DJ Hellfire DJ Hellfire is offline
A couple other things to note is that mono/multi-mono plugins do not seem to be affected. Only seems an issue with stereo plugins.
And the problem can just show up in the middle of a session out of nowhere after just working fine for hours.
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 07-13-2017, 09:50 AM
ok, good to know .. i am about to test this again .. since my Omelette is now "IN My Belly"
standby ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Choosing which EQ/Dynamic plugin opens on Artist mix Interactivesound Artist Series 3 04-04-2017 01:31 PM
Instrument Plugin opens every time I touch fader [email protected] Artist Series 1 12-05-2016 09:32 AM
What's you favorite Plugin Filmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 45 03-28-2010 04:14 AM
What's your favorite compressor plugin? Allbaldo Pro Tools TDM Systems (Mac) 10 06-14-2005 01:35 PM
Favorite Delay plugin celdry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-26-2003 12:36 AM
