Problems with XLR Sockets Stage16
Hi!
I have problems get the XLR plugs out of the stage16 once they were plugged. I have to pull really hard to get them back out - it seems like the locking is not working well any more - on all sockets - it was from the beginning - but now i broke one lock cause i have to remove 1 cable with too much power cause it was stuck in there. By the way - i use Cables with Neutrick Connectors. Did anybody else have troubles here? |
Re: Problems with XLR Sockets Stage16
The XLR jacks on my Stage 16 are a bit finicky as well, but I found a trick that works (for my unit).
While holding the latch release, push the cable deeper into the connector. This seems to fully disengage the latch (you'll feel it release), then the cable can be removed as expected. While this isn't a big deal for me, I could see it being an issue if the board is being used for rentals, or by multiple engineers. |
Aha - ok - never tried that but will remind myself of that.
But that dont fix my broken lock! |
Those panel-mount XLR connectors can be replaced, but plan on a few hours to take things apart, replace and then re-assemble. Anyone with decent soldering skills and a good iron(not that old Weller gun with the coat hanger tip) should be fine
If the box is under warranty then I would not run soldering it myself. I would contact Avid Venue Support first (NB! New phone number for US) to see if it would void the warranty if you replace the connector yourself, or not.
Midi Studio Setup problems & Plugin problems | J Nauti | MIDI | 0 | 03-02-2010 11:04 AM |
Computer Problems vs Pro Tools Problems | mudlake slim | Pro Tools M-Powered (Win) | 1 | 07-14-2006 08:09 PM |
Rewinding Problems, Cutting & Pasting Problems | Nikki | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-22-2005 01:19 PM |
Problems, Problems, Problems all day long... | Jperkins | Pro Tools TDM Systems (Mac) | 5 | 05-12-2005 07:58 AM |
PC Probe problems. Any overheatingg problems with Digi 001 | Ajay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-03-2002 05:30 PM |
