Old 09-28-2012, 05:27 PM
liamMo liamMo is offline
Default Cant Install Pro Tools 8LE from software package
I bought a used 800mhz power mac G4 / 1GB sdram/ and Digi 002 also used.also bought used Pro Tools 8 LE software. System worked fine. I uninstalled PT (Clean), (for reasons i'm not sure of. I now cannot install PT from the disc. When I try to copy the installer package I get an error message.
Finder cannot complete the operation because some data in "Install Pro Tools LE. mpkg" could not be read or written. (Error code -36).
I have never transfered registation. How might I do this
Old 09-28-2012, 10:17 PM
Default Re: Cant Install Pro Tools 8LE from software package
2 possible things come to mind here. 1-there were lots of bad instal CD's with PT8(solution is to download it if you are the registered owner). Or you might be able to copy the installer to the desktop so you don't have to run it from the disk. 2-what OS version do you have. Different OS versions will require different versions of Pro Tools.
Pro Tools Compatibility Grids
follow that link and look for the compatibility grid that lists which version of PT works on each version of OS
Old 09-29-2012, 07:08 AM
I have OSX 10.5.8. I had installed the software back in Feb. and it installed without a problem. I have tried to copy to desktop and and 700mb into copy (Error -36) comes up reading " finder cannot complete operation because some data could not be read or written"
Pro Tools Express Software - Does not Install James1234 Pro Tools Express on Windows 1 11-04-2013 04:57 AM
EuControl Software Package Version 2.6.2 for Mac OS X priorytools Artist Series 1 10-17-2012 09:41 PM
What is the best Software mastering package available?? Gene100 General Discussion 11 04-07-2012 05:16 PM
Instrument Exp Package install Guitarman002 Pro Tools 9 1 11-10-2010 11:12 PM
WTD: Drum Machine Software Package jmkelly Digidesign Hardware & Software 0 12-22-2000 08:24 AM
