Old 09-04-2003, 12:50 PM
chrille2 chrille2 is offline
Default Jerky Video in 6.1
Since I upgraded to 6.1 I have got a more jerky video playback
I have to set video playback to highest mode to get is as smooth as I had in 5.5.3 with medium setting.
Actually..the video playback in 6.1 is so jerky with medium setting that it is impossible to work with.
Why is this ?
I am using a low cpu demanding MJEG compression and my computer is very fast.
It shouldn´t make any difference.
Christian
Old 09-04-2003, 02:47 PM
Datus Datus is offline
Default Re: Jerky Video in 6.1
if you can put the movie into quicktime format .mov I have two clips of the exact same file one mpeg and one quicktime, the quicktime runs perfectly the mpeg is jerky. I think its because the support for movie files in PT is quicktime, and quicktime just happens to play mpegs too.
Stephen Tyler
Old 09-04-2003, 10:04 PM
Hello Datus
Thanks for your reply.
No the video is not in MPEG , which would of course be jerky cause of the cpu intense decoding MPEG has.
The video clip i s MJPEG and I have encoded it myself, runs perfectly smooth in 5.5.3 but jerky in 6.1
cheers
christian
Video playback becomes slow and jerky. hedgerocks Pro Tools TDM Systems (Mac) 24 06-10-2018 10:18 PM
Jerky video playback peter5992 Post - Surround - Video 3 08-02-2012 11:05 AM
BlackMagic video Out : HD fine but SD jerky filmsdunjour Post - Surround - Video 44 07-19-2011 01:20 AM
PT9 on mac pro. Jerky QT video playback!? Sawdust macOS 5 04-18-2011 10:25 PM
Video Playback Very Jerky slinky005 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-14-2009 07:14 PM
