Old 05-06-2019, 11:08 PM
Vercingetorix Vercingetorix is offline
Default Guitar Playback?
Hello guys,
First off, I didn't get my problems sorted with the Guitar Input and Bias products. I had some back and forth with one of the Avid guys who responded to my original question, but, there was no resolution. I ended up having to use re-amp to stop the signal of the Eleven rack coming through into Pro-Tools altogether when using the Bias stuff.
But this question has nothing to do with that this is a new one :) Now I want to play back what I have in ProTools, you know, using transport to play the MIDI tracks, and VST drums, and loop it like a 'backing track' - fine can do that easy enough. But what I want to do is be able to play along with the 'backing track' using my guitar, either the Eleven Rack sounds or Bias tools - don't really care which - I can get the sounds I want with each, but, without recording the guitar and using the studio monitors attached to ProTools to hear the backing tracks and guitar together (again without recording).
Now is this possible? I want to do this for practice purposes because I really suck at guitar and don't want to have to continually record stuff I won't be keeping.
Thankyou and Regards.
V.
You're validating my inherent mistrust of strangers.
Schecter Hellraiser 7 Diamond - Ibanez RG7620
Eleven Rack w/ ERXP
Old 05-06-2019, 11:17 PM
Default Re: Guitar Playback?
Easiest way is to just create another audio track and use that to play your guitar into, with track input monitoring enabled. Use duplicate track to make it easy and delete the audio on that track.
Old 05-07-2019, 02:12 AM
Yeah, I had it all set up on another track but I didn't know there was such a thing called "Track Input Monitoring".
I had to Google the term and I found a video from BenoniStudios talking about it on PT12, and "how you needed to Hit "Alt-K", I'm glad he said that because I'm using PT11 .
Thanks a lot Daryl, I was clueless and this saved me a lot of trouble and much tearing out of what's left of my hair - I had a diabetes episode recently and I lost a LOT of hair. Knowing my luck it probably won't work with my setup but I'll give it a go
Cheers.
Eleven Rack w/ ERXP
Can't hear my guitar during playback 7headed Getting Started 6 06-18-2014 06:00 AM
Getting signal and dry guitar sound but no playback. gcross86 Pro Tools Express on Mac OS X 2 01-09-2013 11:22 AM
Guitar buzz on playback Cone8834 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-15-2010 07:38 AM
Guitar Input Only -- Playback Noise WesleyPipes Pro Tools M-Powered (Win) 0 09-03-2010 05:10 PM
Can't hear guitar on playback only in record..... northwinds Pro Tools M-Powered (Win) 1 10-29-2007 07:39 AM
