Closed Thread
Old 01-19-2009, 08:08 PM
Avid's Avatar
Avid Avid is offline
Administrator
Lightbulb Pro Tools 8.0cs1 Updates
Pro Tools 8.0cs1 updates for all versions of Pro Tools 8.0 are available for download from the Pro Tools CS Updates page in the Support section:
www.digidesign.com/support/csupdates
Pro Tools 8 Systems
The following are the current CS Updates for Pro Tools 8. Previous installation of Pro Tools 8.0 for Mac OS X Leopard, Windows XP, or Windows Vista 32 is required.
Released February 3, 2009:
Released January 19, 2009:
Pro Tools 8.0cs1 includes the following:
All Platforms (HD, LE, M-Powered, Mac & Windows)
Fixed: Converting Sample Rate During Save Copy In or Import Session Data Adversely Affects Volume Automation (Item #111930)
  • Saving a session copy with sample rate conversion to a rate different from the session's may result in erroneous automation ramps between breakpoints. This is mostly evident in scenarios where a static automation level had been changed over the duration of a single region.
Fixed: Crash When Removing Files that are also used in Transfuser (Item #107710)
  • Removing a file from the Pro Tools region list or project browser may crash Pro Tools if another audio file with the same name is already used by Transfuser.
Fixed: Channel width changes may remove downstream mono plug-ins and related automation without warning. (Item #112589)
  • Changing the channel width by inserting a mono-to-stereo plug-in to a mono track will remove a downstream mono plug-in (and all its automation data) that resides on underlying insert slots without warning.
HD Only (HD Mac & Windows)
Fixed: Importing Audio Into a Session With Many Video Regions May Take a Long Time (Item #110829)
  • Sessions containing many video regions may cause audio file import to take a long time. This affects importing from DigiBase or via drag and drop from the desktop and may cause delays of up to 10 seconds per file.
Fixed: Satellite Protocol Communication Issues
  • This fix is recommended for all users of Media Composer-based Video Satellite, Satellite Link, and Video Satellite LE.
  • When using Pro Tools 8.0cs1 or higher with Satellite Link or Video Satellite LE, all connected satellite systems must be running Pro Tools 8.0cs1 or higher.
  • When using Media Composer-based Video Satellite with Pro Tools 8.0cs1 or higher, you must run Avid Media Composer 3.1.2 or higher. Media Composer 3.1.2 updates can be downloaded here:
  • Pro Tools 8.0 cannot be connected as a satellite to other systems running Pro Tools 8.0cs1 or higher, or Media Composer 3.1.2 or higher.
LE Mac Only
  • This fix is recommended for all users of Video Satellite LE
  • When using Pro Tools 8.0cs1 or higher with Video Satellite LE, all connected satellite systems must be running Pro Tools 8.0cs1 or higher.
  • Pro Tools 8.0 cannot be connected as a satellite to other systems running Pro Tools 8.0cs1 or higher.
Administrator
Closed Thread
Pro Tools 8.0cs1 Updates & Satellite Option Updates Avid Post - Surround - Video 1 02-04-2009 12:19 AM
Pro Tools 8.0cs1 Updates & Satellite Option Updates Avid Technical Alerts 2 02-04-2009 12:06 AM
Pro Tools 8.0cs1 Updates midnightrambler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-23-2009 01:56 AM
Pro Tools 8.0cs1 Updates Avid Pro Tools M-Powered (Mac) 0 01-19-2009 08:11 PM
Pro Tools 8.0cs1 Updates & Satellite Option Updates Avid Pro Tools TDM Systems (Mac) 0 01-19-2009 08:00 PM
