Old 03-11-2019, 09:31 AM
alhardy alhardy is offline
Default Protools shifts recorded audio early
This is crazy:
I record a track into a native system to an audio click
Meanwhile I output the native system to my other HD rig and record that at the same time.
This way I can compare what I actually hear while recording to what I see afterwards on the native system grid.
They are different.
The native recorded track is early by 420samples compared to the track recorded in realtime from it's output.
(once imported on native and using click waveforms to allign)
Anyboy has an explanation for this? Please!
System is Macbookpro 2011 with El Capitan 8g ram SSD (but tried also Sierra and High sierra) with a scarlet 2i2 and PT 2018.12. Buffer was 64, but also tried different settings, both buffer and sample rate.
Thanks !!!
Alberto Lombardi
Carbon - Pro Tools
Mac Mini M1
Ferrofish 16 I/O
www.albertolombardi.com
facebook - instagram - youtube
Old 02-02-2021, 06:19 AM
rwhitney rwhitney is offline
Default Re: Protools shifts recorded audio early
Did you ever figure this out? It's suggested to merely trash the PT Pref files. I've been experiencing this problem with PT for many years.
Ross Whitney
[email protected]
iMac 27 (2017) | OS 10.14.6) | 32 GB RAM | PT Native 2020 | Apollo Twin X I/O
Old 02-02-2021, 08:30 AM
I suspect lack of info like sample rate, plugins in use, if LLM was used, etc helped the OP not get a reply to this post from several years ago.
You might get more help for your problem if you describe your issue as clearly as possible, how to reproduce it etc
Can you reproduce your problem in a session with say two tracks and no plugins? UAD complexity with the UAD mixer and potentially some high latency UAD plugins in the mixer or Pro Tools always make me want to afl exactly what plugins are in use where in any IAD system. Can you reproduce your issue using built in input/output?
Latency bug - recorded audio 1ms early RuLemer Pro Tools 12 4 02-07-2018 01:30 PM
Recorded audio placed 40ms too early peteage FireWire & USB Audio Interfaces (Win) 3 09-11-2013 08:05 PM
Recorded audio playing back too early jonwade92 macOS 3 04-15-2013 01:01 PM
Recorded audio too early in relation to backing track MagDee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 02-23-2011 04:23 PM
Recorded audio shifts forward Mad Genius Audio Pro Tools M-Powered (Mac) 2 06-16-2010 07:18 PM
