Old 12-15-2011, 02:02 PM
Clorix Clorix is offline
Default AC-7 Core not working with PT10
I've searched around for help with this issue but I can't seem to find any, so I'll try here first.
With PT9, AC-7 on my iPad worked perfectly. However, with PT10, it seems that Pro Tools can see my iPad in the MIDI Input Devices window, but when I try to set it up in Peripherals > MIDI Controllers, I can't choose a Type from the menu. It only allows me to select "none," so the menus called Receive From, Send To, and # Ch's are grayed out.
AC-7 works fine with another DAW I use frequently. I'm not a professional or anything. I just do this as a hobby, so I'm only somewhat familiar with how it all works. But like I said, it worked fine in PT9. The only difference is that I now have PT10 installed.
I don't know if it's an issue with Pro Tools or with AC-7. If it helps, I'm running the latest AC-7 Core, Pro Tools 10.0.0, and am using Windows 7 Professional 64-bit.
Thanks in advance!
Old 04-10-2012, 06:17 AM
daniel_m89 daniel_m89 is offline
Default Re: AC-7 Core not working with PT10
Hi... I just got The pro tools 10 ADN The ac 7 core and it works but not as I want. It doesnt work The time code and The meters and some Bottons. The set up its just The ac 7 page says.
I think we Need some help
Thanks
Old 04-10-2012, 08:53 AM
Thanks
Eyy i just set up The ac7 with a PT9 and it works perfect, then i go back to my pro tools 10 and it works perfect, i dont know how Was or why the reason of The problem.
I think You show try set it up on a previews pro tools versión and go back to PT 10
I think is wired
Core Audio not working on TDM PT10 316 Pro Tools TDM Systems (Mac) 0 10-03-2013 03:51 PM
Possible to run HD Core 1 ASIO w/o installing PT10 ? dan98 Windows 2 05-30-2013 02:23 AM
Advice Needed Re: AMD 6 Core Compatibility with PT10 Meinzi Pro Tools 10 12 06-14-2012 11:44 PM
PT10 working off of a NAS Frank Kruse Post - Surround - Video 19 01-27-2012 04:27 PM
Quad core CPU with PT10 digi003 Pro Tools 10 5 01-11-2012 08:14 PM
