import session data-Protools quits
After being Kernel Crash "free" for 3 months it finally happened. after finishing a mix, PTools unexpectly quit, then the grey curtain of doom shows its ugly side. full kernel!!. i throw out all the regular stuff fix permissisons no problem reboot. i begin to import mix session data to a new song. as its importing it unexpectly quits, but no kernel crash. this happens 6x in a row. My system is at OS 10.3.4 with PT 7.1.cs4. i read the newest cs7 updates and it says it has fixed the problem with "import session data" and other issues. i upgrade the OS to 10.4.6 combo, fix permissions and update to the new cs7. the same things happen when importing session data.
Anyone have the same problem? the only problems i have had previous was after installing SSL4K bundle, my Control 24 would lose communitcation. Rig: is G5/2.3 10.4.6, 2.5 gigs ram, HD3 accel PT 7.1.cs7 |
Re: import session data-Protools quits
i get this when I import tracks that have waves tdm plugs on them from an older version of pro tools. I am still running waves 4.0 and rtas plaugs work great, but tdm ones crash PT. When I import tracks that have waves tdm plugs on them, I launch pro tools without the wavesshell. Then i innactivate the track. Then I relaunch PT with the waveshell and convert the waves plugs on the inactive tracks to RTAS from TDM. Then I reactivate the tracks and all is well.
this is a strange situation, and probably has nothing to do with you, but you never know... good luck |
it could be the SSL 4k, but i think now i had a corrupt sessions causing this. i forget to wait as the session to close before i open another, being a little impatient i go to open another session and PT will unexpectantly quit. closing down a session pre 7.0 was a little different.
thanks for your info about the waves, i should update the SSL4k 2.0 landy |
Protools bug? - Unable to import session data | andy1357 | Getting Started | 0 | 05-21-2013 05:39 AM |
Protools 10.3 Crashing with import session data on Mountain Lion | electroteque | macOS | 11 | 12-01-2012 01:51 PM |
import session data without audio data | rgalpin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-06-2010 01:49 PM |
Problem with Import Session Data in ProTools 8 | Corto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 02-16-2009 04:35 PM |
Import track color in import session data | deardaddy | Pro Tools TDM Systems (Mac) | 5 | 06-11-2007 06:35 PM |
