direct i/o vs. asio
Does anybody know of any reasons for preferring either asio or direct i/o for use with Logic 5.5?
Thanks. |
Re: direct i/o vs. asio
I'm unaware of any Digidesign product called "Logic 5.5"
Direct IO is better then ASIO IMHO. It is much longer around as the ASIO-drivers, so the bugs are worked out better i think.
What's that? - That's the machine that goes "pling". Bastiaan |
www.myspace.com/krou |
I think the AISO drivers work better in Logic than Direct i/o?
Plus you can use them in other programs as well! JK London N719 |
Did Digi ever fix the MIDI problem with ASIO?
I remember earlier that the MIDI ports on the Digi card did not work with ASIO but they should with Direct I/O. |
The digi ASIO driver however requires that the wavedriver be uninstalled (meaning no more MIDI port). The only gotcha however is with wavedriver+DirectIO logic will crash on the DIOMIDI.DLL on exit. Digidesign blame emagic, and emagic blame digidesign eitherway it will never be fixed since Logic is no longer supported on the PC. Cheers, Marcus |
ASIO Direct I/O driver for 001 | adamus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-29-2002 08:58 AM |
Latency: ASIO or Direct I/O | alk509 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 04-04-2002 01:04 PM |
ASIO Direct I/O | drenched | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-20-2001 08:01 AM |
asio vs direct I/O | raunsbj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-16-2000 01:34 AM |
Direct I/O vs. ASIO | wazoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-29-2000 09:48 AM |
