Moving MIDI notes: how vertically constrain movement?
When moving MIDI notes up and down, how do you vertically constrain movement? I've tried CMD-Click/drag, but this seems to not apply to MIDI.
I recall Logic having some way of doing this. |
Re: Moving MIDI notes: how vertically constrain movement?
Try relative grid mode!
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Or only ctrl+drag?
I'm in grid mode already, for both tracking and MIDI.
I've tried CTRL-Drag, CMD-Drag, along with various other combinations, but I can't figure it out. |
Shift drag. Whatever direction you drag first(horizontal or vertical) the other will be locked.
Hmmm. Why is it shift with Midi but ctrl with audio?
Thanks. It is SHIFT-drag, but the trick is that you apparently have to hold SHIFT before clicking the mouse. I was clicking and then holding SHIFT.
So, it's 1. Click and hold SHIFT 2. Click the pointer on the note 3. Drag it. It should be constrained to only vertical or horizontal movement. I just wanted to update this thread, in case anyone else had the same question. |
constrain movement to vertical of midi parts | bassmagnetic | Pro Tools 12 | 4 | 12-05-2016 04:51 AM |
Can I vertically align all selected MIDI notes in one go? | dhjdhj | Pro Tools 10 | 4 | 05-20-2012 05:31 AM |
Moving midi notes | Tim Rector | MIDI | 3 | 12-01-2007 04:19 PM |
moving midi notes | Toefinger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-28-2006 01:30 PM |
Moving MIDI Notes | Dog BBQ | Pro Tools TDM Systems (Mac) | 3 | 10-12-2000 06:02 AM |
