Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 08-30-2013, 09:18 PM
donvision donvision is offline
Default Delay Compensation red with or without plugins
hello,
my delay compensation is red in the edit window with no plugins on my tracks. I've trashed prefs, etc and still no change. the only way to get it to be green is to delete all tracks (which makes it kinda hard to mix or record haha). looking in the edit window track details, the delay compensation reads 0 on each track.
in another scenario, with native plugins on the tracks only, and either DSP plugs or none on the auxes/master it still shows red in the edit window. this has caused issues with clients when sometimes this delay compensation issue will affect the playback of certain tracks, taking them out of time. in these use cases, things are as they should be with native plugins on tracks only as I've described.
In all cases I've described, delay compensation is set to maximum. I'm using PT HD 10.3.6 with HDx hardware. I've fooled around with other settings in the playback engine dialoge (# of cores, etc) to see if it might help to avail. when I first installed, upping the # of cores would remedy this problem.
I appreciate you reading this and I welcome your helpful suggestions/ideas about anything I may have missed. If I sing "With or without you" about my plugins (specifically Waves right now) it makes me feel a little better.
-D
Old 08-31-2013, 01:18 PM
Craig F Craig F is offline
Default Re: Delay Compensation red with or without plugins
there are some routing sett ups that can do this
hovering the pointer over the DLY a pop-up should tell you were the problem is
if you could post some screen caps, use the Print Screen to capture you screen, then go into Paint and past the screen cap, then save the image
Thank you,
Craig
Old 09-01-2013, 08:51 PM
Yes, routing can make some weird stuff happen. I just posted about a track(with no plugins) showing 1177 samples of delay compensation when its output was set to a bus. Set the output to the main outs and the latency goes away. Things that make you go "hmmmmm"
Old 09-08-2013, 08:34 PM
really appreciate the help guys, I did not know that hovering over the DLY would tell me what was wrong. you learn something new every day!
it was indeed the routing in the bus section of my IO. got rid of the funky busses and made new ones which fixed the problems.
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing CNSound macOS 1 01-27-2012 11:10 AM
Delay compensation- choice of 'Medium delay'? dtmprod Pro Tools TDM Systems (Mac) 2 05-05-2010 11:00 PM
delay compensation for rtas plugins...?? lukeyy Pro Tools TDM Systems (Mac) 0 11-14-2006 11:23 AM
Automatic plugins delay compensation ... Caballero Pro Tools M-Powered (Win) 4 03-31-2006 09:47 PM
RTAS plugins and Auto Delay Compensation?? Jon_Atkinson Pro Tools TDM Systems (Mac) 6 05-22-2005 05:35 AM
