Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 02-04-2018, 03:30 PM
Jperkins Jperkins is offline
Default Audio Zoom In and Audio Zoom Out Shortcut
5 minutes on Google hasn't helped so now I must ask this here:
Is there a shortcut for increasing or decreasing the vertical zoom level of waveforms in Pro Tools to see really quiet passages?
iMac Pro 3.0GHz 10-Core • 64GB RAM • SSD for OS and audio • MacOS 10.13.3
http://www.mysteryroommastering.com/
http://www.justincarlperkins.com/
Old 02-04-2018, 04:31 PM
BScout BScout is offline
Default Re: Vertical Waveform Zoom Shortcut
the shortcut is
cmd+option+ [ or ] for vertical zoom
and
cmd + [ or ] is the horizontal zoom
Old 02-04-2018, 04:34 PM
Originally Posted by BScout View Post
the shortcut is
and
Thanks but this isn't working for me.
To be clear, I'm trying to zoom in the waveform so that it becomes inflated so I can view low level audio stuff.
I'm not asking to make the track larger.
Audio Zoom In and Audio Zoom Out is what it's called when I do it manually.
Old 02-04-2018, 04:56 PM
zoff zoff is offline
T= zoom in, R= zoom out
macOS Catalina 10.15.6
Intel Core i9 MacBook Pro 16-inch, 2019
32 GB RAM
Pro Tools 2020.50
RME Babyface Pro
Old 02-04-2018, 05:41 PM
Default Re: Audio Zoom In and Audio Zoom Out Shortcut
Then T and R, as zoff says, to zoom in and out. If you want to enlarge vertically, you have to also enlarge the track which is ctrl+ up and down arrows.
Old 02-04-2018, 06:25 PM
I'm talking about increasing the size of the waveform, similar to how Clip Gain might do but without affecting the audio level.
I'm aware that R & T are used to zoom in and out but this is not what I'm referring to.
Old 02-04-2018, 06:27 PM
There is another form of zooming that can be done by using the tool bar, but I am hoping there is a shortcut for it. It doesn't involve changing the track size, it just makes the waveforms more blown up so you can see quiet stuff.
See the screen shot.
File Type: png Screen Shot 2018-02-04 at 8.26.37 PM.png (16.2 KB, 0 views)
Old 02-04-2018, 10:06 PM
And that is what I told you how to do in post #2. That is exactly what command+option+ square bracket does. That does Audio Zoom In and Out
And the other setting of command+ square bracket does the other part of that section of tools: Horizontal Zoom In and Out.
That is why they are one modifier key away from each other.
Old 02-05-2018, 05:20 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Set your zoom presets . Upper right corner of the edit window is the waveform and midi enlarge buttons. Left and right click to get the size you want then save it as a zoom preset.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 32 Gig Memory:Seagate 2 TB,1TB,4TB,500gb EVO OS Windows 7 Ultimate
PT 2019.6 Native through A&H Qu-32
Old 02-05-2018, 08:57 AM
The Weed's Avatar
The Weed The Weed is offline
Try Alt+Shift+Scroll Wheel (PC).
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
I can not make vertical zoom Shortcut cmbourget Windows 8 05-08-2015 04:35 PM
Vertical zoom to show default waveform height (Audio) with D-Command ? Hanswurstlsepp ICON & C|24 0 06-30-2011 03:55 AM
Vertical edit zoom shortcut, where / what is it? Strebor24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-29-2010 06:15 PM
Waveform vertical zoom thing... Kuba Pietrzak Post - Surround - Video 6 01-17-2008 12:31 PM
Vertical single waveform zoom - not working sonuslab Pro Tools M-Powered (Win) 7 10-19-2006 05:34 AM
