Old 07-27-2007, 07:03 PM
Chap Chap is offline
Default Secrets to opening older sessions in PT 7 HD
Howdy,
I'm wondering if anyone knows how to open sessions that originated in PT 4 or older
in PT 7.3 HD? Decoder kit? 3rd party software? Magic ring?
Or, it's obvious and I'm an idiot (it's possible). Either way,
I'd appreciate any tips.
Thanks in advance,
chap
Old 07-28-2007, 08:32 AM
Default Re: Secrets to opening older sessions in PT 7 HD
c'mon now, this isn't the Skull and Bones society. Let's have at it.
Old 07-28-2007, 12:27 PM
Touchwood Studios Touchwood Studios is offline
Find a G4 install Protools 5.3.1
We are doing a re-mix project( From (Protools 4 1998) all the session had to be opened up in Protools 5 saved then opened in 7.3
None of the Midi tracks translated. It was a huge pain but it worked
Old 07-29-2007, 07:16 AM
I was going to try that but my G4 croaked. Plus, I would need to connect to some
digi hardware and install a pci card. Shouldn't this be a simple thing?
From the amount of responses, it doesn't appear to be a pressing concern for many
people.
Maybe it will get more light as more folks develop a need to reexamine older
material.
thanks,
chap
Old 07-29-2007, 07:40 AM
rockridge's Avatar
rockridge rockridge is offline
in PT 7.3 HD?
You would think that 7.3 would be able to import anything created on PT previous versions.
I guess your options are to fix your G4 or buy another... or find someone who has an older working system, and have them do the conversion for you.
But consider this, I've been in situations where i was convinced i couldn't live without the original version of something only to find out that my memory of the session was optimistically inflated.
In other words, are you sure it's worth the trouble? If you redo the session from scratch now, you might do circles around what you had.
Protools 10.3.10/11.3.2/12.6 | Win 7 Ultimate 64 bit
Old 07-29-2007, 07:41 AM
rockridge's Avatar
in PT 7.3 HD?
You would think that 7.3 would be able to import anything created on previous PT versions.
web page
Old 07-29-2007, 06:55 PM
Avid's Avatar
Avid Avid is offline
Administrator
I have no idea if this will work, but try this...
Make a copy of the orignal session folder first, then...
Get Info on the session file.
1 - If you think it is a Pro Tools 4 session, add ".p24" to the name for a 24-bit session.
Or ".pt4" if it is a 16-bit session.
2 - Check the File Type and Creator with something like the freeware utility:
Quick Change
Enter PT24 for file type and PTul for the creator.
3 - Choose your current Pro Tools application as the "open with" app.
Step 2 might help without the other steps, depending on what the original file format was. It sounds like it could have had the resource forks stripped somewhere along the way.
Administrator
Old 07-29-2007, 09:00 PM
Kenny Gioia Kenny Gioia is offline
Nobody is running Pro Tools 5.xxx and can help this guy out converting the file?
Come on!!!!
Old 07-29-2007, 09:17 PM
5.x would require all the audio not just the session... if memory serves.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
HD10 Delay Compensation Red alert when opening older sessions. Firechild Pro Tools TDM Systems (Mac) 2 11-29-2011 05:49 PM
Overview redraw when opening older V7 Sessions georgelegeriii Pro Tools TDM Systems (Mac) 2 12-26-2009 03:41 PM
Opening HD 7.4.2 Sessions on Older Versions Lumin Pro Tools TDM Systems (Mac) 2 10-30-2008 02:13 PM
PT7 crashing when opening older sessions mwingerski Pro Tools TDM Systems (Mac) 4 02-18-2006 03:54 AM
Crashing when opening up older sessions IO Composer Pro Tools TDM Systems (Mac) 3 02-25-2005 05:14 PM
