Old 07-13-2006, 05:38 PM
meekmonk meekmonk is offline
Default Problem- PT 7.1.1/Focusrite ISA 428 and 96K record
Hi there.
Just upgraded from Mbox to 002 Rack. Got it all set up and running fine with Focusrite Prepak into 002 via lightpipe running @24/48..
I figured that if I wanted to record at 96K I could just set Focusrite to 96K and open up a new PT file at 96K.
Boy am I naive sometimes!
Anyway was wondering if anyone could walk me thru the set up for 96k 24bit recording with lightpipe and ISA prepak?
I would be so happy......
MM
System 10.4.7, 17inch Macbook Pro, 1Gig ram, 120 gig LaCie firewire drive, PT 7.1.1, Focusrite ISA 428 Prepak going lightpipe into 002.
Mac Pro, 2/2.4 GHz Quad-Core Intel Xeon
16 GB 1066 MHz DDR3
System 10.7.3 PT 9.0.6
MOTU 8Pre, Focusrite ISA426, Millennia HV-3C, UA 6176
Old 07-13-2006, 09:11 PM
kurt's Avatar
kurt kurt is offline
Default Re: Problem- PT 7.1.1/Focusrite ISA 428 and 96K record
Light Pipe is 44.1/48kHz. Higher than that you have to use SMUX protocol. (Do a Google). I´m not sure if 002 support that. Try SP/DIF. (Only 2 channels )
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5
PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear.
http://www.mmvstudios.com
PT 10 with Saffire pro 40 (Focusrite) problem universeuv777 Third Party Interfaces 6 09-30-2013 05:19 PM
focusrite ISA Adat Out Problem wolfman_rob Pro Tools TDM Systems (Mac) 2 03-28-2009 04:31 PM
Record Punch Problem: Hear old take/Record new take Felix Rost Pro Tools TDM Systems (Mac) 5 01-04-2008 11:29 AM
Record instrument through focusrite preamps. Digital Musician 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-22-2002 09:49 AM
Focusrite D3 Still a problem talkingdog Pro Tools TDM Systems (Mac) 0 01-16-2002 06:40 AM
